Old 09-21-2015, 06:33 PM   #1
johnnybev81
johnnybev81 is on a distinguished road
Mad Trouble with drum brakes on my 2002 L100
The inside shoe on my driver side rear drum brake was worn down to the metal of the shoe. Following what little info I could find, I managed to unhook the spring for the auto adjuster which is positioned on the top, then the smaller hooked spring which connects the star wheel assembly's retaining clip to the shoe frame, and also the retaining spring and cup which hold the shoe on the assembly. No troubles except for a two inch compression spring which dropped out when the star wheel assembly came out. After examining the other side and not seeing anywhere for the compression spring to go, I put it inside the star wheel assembly's stationary piece which sits against the outside shoe.
Long story short, I have to pump the brakes now to fully stop the car. I took the wheel and drum back off again to inspect it and the retaining clip was not holding onto the star wheel - it was hanging down slightly away from the SW instead of engaging it. I manually adjusted the SW tighter to give more resistance when spinning the drum, put everything back on and did another test drive. Same results. The brakes still need to be pumped before the brake pedal has resistance.
What did I do wrong? Any help will be dry appreciated.
johnnybev81 is offline   Reply With Quote
Old 09-21-2015, 08:37 PM   #2
Default Re: Trouble with drum brakes on my 2002 L100
While diy can be rewarding when repairs go right, not having familiarity and experience servicing brakes can be an accident waiting to happen. Fortunately, if you spend time Googling and searching youtube videos, you'll have more info for immediate review if a service manual isn't around. Don't be discouraged by what you find. In general, all drum brakes use similar parts and operate the same way, expanding a pair of brake shoes into the inside drum surface to stop the drum from turning. Any picture or exploded diagram will help with familiarization of where parts go and how they're used. If you study drum brakes you'll see basically four sections; a pair of brake shoes being operated by the hydraulic wheel cylinder pistons, the retaining hardware to hold the brake shoes upright, the springs to pull the brake shoes away from the drum and the star wheel adjuster. Some bemoan drum brakes and their complexity compared to disc brakes but ignore history. Drum brakes were adaptations from horse drawn carriages and used safely for many years before the aircraft industry developed disc brakes. The auto industry simply adopted disc brakes for cars. Every truck has drum brakes and work fine otherwise we'd hear about it. Drum brakes falls into two areas; mechanical parts and hydraulics. Repair whatever mechanical parts need replacement and adjustment. The wheel cylinder pistons depends on a pair of pistons and rubber seals to keep brake fluid in and allow pedal pressure to push pistons out against each brake shoe. If brake fluid was never replaced after brakes were serviced, fluid may have absorbed moisture over the years and can cause corrosion within the system. Flushing and bleeding brakes are normal procedures many are in fear of from lack of knowledge. Couple abs complications and more are reluctant to replace brake fluid. Instead of turning to a brake shop for this service, many ignore it based on "the brakes work perfectly after I replaced all the brake parts". Like motor oil, brake oil needs to be replaced periodically.
Mechanical parts are relatively easy to understand
Old 09-21-2015, 09:19 PM   #3
johnnybev81
Haha, nice typo, right? Dry=very. Stupid iPhone. The thing that's the weirdest is that the clip which maintains the position of the star wheel doesn't hold its position. The brakes worked before, even with the heavily worn shoe.
Old 09-24-2015, 08:06 AM   #4
johnnybev81
Thumbs Up Re: Trouble with drum brakes on my 2002 L100
I figured I'd post a follow up in case it can benefit anybody. There are two forked ends to the automatic adjuster assembly. Even if you have the forked ends facing the correct direction, if the end closest to the star wheel is not put in right side up, the lever which operates the star wheel not have be able to stay against the star (gear).
Yesterday I took off the wheel and drum again and removed the secondary or "inside" shoe to carefully re-examine the issue when I noticed there is an additional notch on the fork which holds the lever up. That was the source of my trouble as the incorrect positioning of that work will lead to no tension on the star wheel.
Bleeding the brakes is important, of course, but was not the source of my problem (which I've noticed people in other car forums also encountered but were never answered with this simple solution).
Now to just buy a brake spoon and readjust the star wheel one last time before slamming the brakes while going 5mph in reverse a few times to finish the job.
p.s. Drum brakes are 1,000x more tedious than disc brakes and maybe the days of horse drawn carts is where they should have stayed in history.
Old 09-24-2015, 10:40 AM   #5
Drum brakes work fine when maintained. A person unfamiliar with drum brakes can cause brake problems........
Old 09-24-2015, 10:51 AM   #6
floridasl22002
Johnny,
When working on drum brakes (thank god for disc brakes) don't work on both sides at the same time. If you have problems re-installing parts on one side, just go to the opposite side and check the placement of parts. It's really as simple as that.
I hate working on drum brakes due to their fiddliness (if that's a word?)
Old 09-26-2015, 09:18 PM   #7
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
+1 on the difficulty level working on drum brakes WRT disc brakes. I did a DIY for L-Series front discs that is in the HowTo forum. Simple stuff. I purposely didn't do one for the drums, because I think most DIY mechanics can get into trouble with these. There are many (mostly wrong) ways to reassemble the parts after you get them apart. You can take a digital photo before taking anything apart as a guide or you can peek at the other side for help. The line diagrams in the FSM are so vague as to be of little guidance. Then there is the possibility that a previous mechanic or DIY repair scrambled some parts before you got there. All these can result in improper operation. My experience is that there are two main difficulties with these. The first is that everything goes sproing when you try to re-hook the tension springs on the shoes, the pistons come out of the cylinder and you have brake fluid everywhere and air in the system. To prevent this, fasten a belt strap or rope around the shoes before trying the hook on the springs. The other problem is when using aftermarket shoes the flat blade portion of the shoe is slightly thinner than the OEM ones. The fork on the end of the adjuster is now a little too wide to keep the thin sheet metal pawl for the adjuster rachet from dropping into the fork gap. The result is the brakes will not self adjust and you won't be able to apply the handbrake and the pedal will have too much travel. The cure for this is to squeeze the fork slot a little tighter in a vise. Add in the tiny fragile bleeders that weld themselves into the aluminum cylinder bodies and you have a whole bunch of issues. I forgot one. There is the ridge of rust that builds up on the edge of the drum that needs to be removed before it will go back on over the new shoes.
Old 09-26-2015, 09:38 PM   #8
Actually, the ridge of rust on the edge of drums is the original drum surface never touched by brake shoes. What you see is the result of normal wear and tear of drums worn away where brake shoes make contact, leaving the ridge. Its not rust growing, just original metal.
Old 05-10-2021, 09:41 AM   #9
havai
havai is on a distinguished road
Dizzy Re: Trouble with drum brakes on my 2002 L100
I recently obtained 2002 L100, and I too desperately need to find a precise diagram of how the springs, shoes and components are to fit together.... I'm really annoyed to yet again encounter the "drum brakes are all the same" since covered wagons arrogance..... and/or the ole' take photos and/or don't touch the good side. All useless for me, as my working hunch is that a mechanic who'd serviced the vehicle over the past decade repeatedly was installing components (on both sides!) incorrectly, such that in multiple service calls, owner was reporting the springs, adjusters, etc. were (literally) falling off inside the drum. Has now happened to me twice.
What's especially mind-boggling is the utter lack of repair videos for this job, or precise diagrams -- not in Haynes, Chilton (same thing) or even AllData....
So please, no more knowing crap about covered wagons. Anybody have an actual photo/diagram set for exactly how the shoes, springs, adjuster, and parking brake lever (the real issue) are to line up inside the drums on the L-series?
havai is offline   Reply With Quote
Tags
l100 drum brakes trouble
2002 Saturn L100 running rough and trouble starting frankmassa L-Series Tech 7 10-20-2019 02:11 PM
Converting rear drum brakes to disc brakes Sliverstreak02 Vue Red Line 17 03-19-2016 06:10 PM
Brakes on a 2002 L100 radioouman L-Series Tech 1 04-16-2010 11:45 AM
2002 L100 rear brake noise - drum recommendation? atldad L-Series Tech 3 09-06-2009 09:39 PM
L100 Brake Drum production Brakeman Ion General 4 10-25-2001 11:15 AM
