Thread Tools | Display Modes |
#1 |
![]() Join Date: Jun 2022
2003 L-Series 2.2L Wagon
Hey guys, new to the forum. I picked up a 2003 LW200, runs well with over 190k miles and most things work well. However, I do have some issues, and some were hard to find answers for on this forum and elsewhere.
First, I’d really like to know what I should check and replace with this car. I’ve already done the oil and filter plus the spark plugs (was developing an intermittent misfire), and plan to flush the coolant and brake fluid as well as the air and fuel filters. The belts seem decent, as are the tires. Are any of those hard to reach, or do any of them have any then to get hung up on? Is the automatic transmission sealed, or should I be looking to replace the ATF as well? Are there any other items that may need done preventatively before 200k? Now to the issues I’m facing, and I’ll just list them here: The car has a bit of a stutter when accelerating from a stop - it feels a bit like a misfire but only directly upon acceleration. This is most noticeable when the engine is cool and the air is hot - I’m planning to clean the throttle body and idle control valves with some carb cleaner, because I’m thinking it’s possible the throttle is a bit gunked up and slow to respond, but I’m curious if there are any common issues that could cause this. The parking brake doesn’t appreciably slow the car - I had the front up on stands while changing the oil, and while I of course chocked the rear wheels and left it in park, the handbrake was fully pulled and had zero effect on the car, which rolled hard against the chocks (to the point of breaking one of the bricks I was using); plus I’ve pulled it at highway speed to minimal effect. This could be related to a creaking sound from the rear brakes upon pedal application that I hope to fix with the brake fluid change and a closer visual check on the pads and rotors. There’s a small coolant leak I discovered while changing the oil, it runs down the back of the block and drips (slowly) further back than the oil pan, right around the heat shield. There is never a puddle under the car, but every few weeks the dash light comes on and it needs topped off. The oil I removed from the car was dark (and nonmetallic), so I highly doubt it’s the head gasket leaking - it’s seemingly more an annoyance than a problem, but I couldn’t trace it up, so if anybody has a list of places coolant might be leaking from where it would run down of the rear of the block, I’d love to stop it. The HVAC is stuck on the defroster, while the other HVAC controls work. I found this post that seems to diagnose it as the mode actuator, so I’ll be checking that and looking for one from a junkyard: http://www.saturnfans.com/forums/sho....php?p=2262505 The air conditioner doesn’t work - I believe the most likely cause would just be that it needs recharged, but again, if there’s a common issue, let me know. And a final minor irritation (which seems to be common on these cars if the Regular Car Reviews episode is something to go by), the hinges in the interior seem weak and both the center console lid and one of the wings on the spare tire cover panel have broken off. Has anybody found a good way to fix these, or should I just trawl the junkyards or live with it? Sorry for the huge post, and I appreciate all help! Last edited by doyle524; 06-29-2022 at 07:40 PM. Reason: Typo |
#2 |
I can address ac issues with other L200 owners hopefully addressing your list of problems.
Most vehicle owners assume their ac systems need recharging when loss of cooling occurs. This assumption is wrong. Service valves on vehicle ac systems are put there for the eventual repairs that comes from attempting to flex aluminum tubing from every pothole and corrosion occurring from unprotected bare aluminum fittings. If everyone can imagine repairing their refrigerators, freezers, central hvac and room ac units as impossible then the same consideration should be given to vehicle ac systems. All refrigeration systems, including vehicle ac systems are considered sealed from factory assembly and warranted under new car guidelines. If ac fails during warranty, dealers are obligated to repair and restore it back to factory condition. After warranty, dealers, repair shops and diyers with knowledge can repair them. Personally, 98% of all vehicle ac system problems is the leak no one wants to address but will run to the auto store for the refill kit(s) in hopes of a low cost repair (in a can), refilling........a leaking system. Most refill kits have sealer reputable dealers, repair shops and diyers will never use because it contaminates the system, rarely works and creates a large repair bill when repairs are needed that makes money for dealers and repair shops as a system is completely disassembled and flushed of refrigerant, oil and sealer. Damage from sealer use may require replacing the condenser coil, drier, txv and compressor - a very expensive repair that would have been less by a simple diagnosis; using an inexpensive uv blacklight to shine on every part of the ac system parts to illuminate factory installed dye, glowing greenish yellow in shade, indoors or after sunset. A simple use of a uv light should show where the leak occurred that released refrigerant. Sealer hasn't been overwhelmingly successful. Search these forums and any other car, pickup truck or suv forum and see if there's a positive consensus of ac sealer in a can. Ac mechanic in a can rarely works. Spending 10-30 minutes with a uv light should make dye glow where invisible refrigerant leaked out along with oil. Dye glows when illuminated by a uv light. If you able to do this then you can decide which way to proceed instead of refilling a............leaking system. If you insist, waste a can of r134a (without sealer) and use the uv light. Good examples of dye; both service valves when caps are removed. |
#3 |
That’s some excellent info, fdryer, thank you! I knew self-sealing products were bad news, because any air pockets will create solid blockages, especially in intricate fins etc. I was just going by what I’ve heard people around me talk about having their mechanic do when their ac stops blowing cold. I’ll grab a UV light and check it out rather than wasting refrigerant.
#4 | |
![]() Quote:
However, the hesitation seems to have gotten a bit *worse* rather than better. I’ve narrowed it down to a hesitation when accelerating moderately or hard from a standing stop or thereabouts - a smooth gentle acceleration has no hesitation, and even a 5mph coast before acceleration prevents the hesitation. Next guess is the throttle position sensor, assuming I can get to it - is there an easier way to reach the stuff around the throttle body? |
#5 |
My L300 has four wheel disk brakes. The rear discs are a top hat design; the disc has a hub that serves as a drum brake. The drum brake is very small and not designed for emergency braking by any stretch of the imagination. It's main purpose is hill holding as a parking brake. If your LW200 has rear discs then they're most likely designed the same way. L200s, LW200s and L300s share many parts.
Look up parts on rockauto for images besides comparing prices. With close to 200k miles, either ecotec engines last with periodic maintenance or break down at random like ignition coil or ignition control module failure. A search in forums of ecotec engines, the most popular being the 2.2L, should show a pattern of icm failures with the coil pack holding up. Putting the icm onto a cavity on the coil pack sitting over a hot engine can provide real world consequences of random failures or intermittent operation. Another possible issue may be fuel pressure requiring a pressure gauge borrowed from AutoZone or other big box store with a free loaners. |
#6 | |||
![]() Quote:
Checking ATF: there is an 11mm head inspection plug on the transaxle located to the right of the vehicle's center near where the nose begins to extend out to the r/h axle. With the engine warm and running remove the plug. If no ATF runs out then begin to slowly add until you can see fluid exiting the inspection hole. There are varying requirements about when to replace the ATF based on the conditions one is regularly driving in. I drain the transmission at a 50K mile interval and it has never seen a repair. If one is queasy about being underneath a car with the engine running then a mechanic should do this to check the level of the ATF. Lastly, if you're draining the transmission the refill is officially at 6.9 quarts. One tenth of a quart is 3.2 fluid ounces. Put in a full seven quarts and don't worry about it. That minimal overfill will cause no problems. I've done it several times with no negative consequences. You don't even need to check the level after you're done! Radiator flush: absolutely do not use tap water. The system requires distilled water only. Additionally, this job can get messy really fast! There are two points to drain antifreeze from - the drain cock at the lower right of the radiator and at the bottom of the water pump's rear cover. IIRC, the plug's head is 13mm and you need to use a wrench (not enough space for a ratchet and socket ![]() Quote:
395K miles (engine replaced @ 375K). Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct. |
#7 |
Correct name the for junction: Inlet Assembly. The pipe is referred to as the Radiator inlet pipe.
#8 |
Thank you Pierrot, there’s so much useful information there!
I discovered a slightly more pressing issue, noticed while diagnosing my onset steering misalignment which changes depending on whether I’m accelerating or decelerating - I’ve got a big ol’ hole (pretty much turning the box frame into an “n”-frame for about a 3” section of the frame) in the bottom of the front subframe on the passenger side (likely no thanks to the plastic shelf that has to collect snow, salt, and water and hold it against the frame). So with that context in mind, going from a straight steering wheel under acceleration to a good 30° of left hand down under braking (plus some visible camber difference vs the drivers side when stationary) is pretty alarming and seems to suggest an impending failure… Are there any good resources that could help me find a clean(ish) front subframe? I’m in Ohio so I assume most junkyard models will have similar oxidation… GMPartsDirect has one listed, but at $1000 it’s an absolute joke; I see a few on eBay for around $400-500 but I’m not sure how much I trust them, especially when they’ve been painted. I assume I’ll need to support the engine to remove the subframe - can I just chuck a jack under the block or will that risk damage to the oil pan, and if so, what is the best way to support the L4? While I have it suspended, are there any engine parts to check or replace that might be hard or impossible to access otherwise? On that topic, what are the telltale signs of a healthy or unhealthy L61? If my car is out of commission anyway, I don’t mind disassembling the block (within reason) to ensure the engine will last long enough to make a subframe repair worth it, since a replacement engine looks like it’ll cost more than the car itself did. What parts should I be looking to replace in tandem? I’m sure a lot of the bearings/seals/mounts/bushings etc will be old and in poor condition. While I’m removing the suspension anyway, I might as well consider replacing some of the parts with new ones for better performance, longevity, and looks. What upgrades/replacements are most impactful on the front end? Are there decent coilovers, perhaps that lower the ride height a bit as well? |
#9 | ||||||
![]() Quote:
to look for subframes (engine cradles to car-part) across North America and Mexico. There are many available. Read the website carefully to understand the part quality ratings. There are businesses which clearly state that they do not ship this part. Quote:
#10 |
You (and the rest of this forum) are such a wealth of knowledge, especially for a brand that’s been buried for so long!
Got it up on a trusted shop’s lift today, they agreed that everything else looks solid so I’m picking up the subframe this weekend, ordering some OEM control arms, and getting it all replaced. And so the most pressing issue is, once again, the hesitation under strong acceleration. I replaced the fuel filter (think the one I pulled off may have been the original from 2003 - I certainly had to drill out the screw holding it in, so it hadn’t been done any time recently) and it feels happier to rev as well as smoother on idle, but the hesitation is still there, so moving down the chain (and up in price) I believe the next potential culprit would be the injectors. I know I can buy aftermarket ones new, but I assume any injectors off an L61 will fit, and I bet there are some higher performance injectors that came stock on some GM cousins which I could pluck out of a junkyard for cheaper than getting an OEM spec set new, but it’s hard to find specs even with the AC Delco part numbers. First, what injectors fit our configuration, and second, which are an upgrade over our stock ones? |
#11 | |||
![]() Quote:
https://www.gmpartscenter.net/oem-pa...w0LWdhcw%3D%3D What we don't know - unless someone trusted can confirm it - is what other injectors can be used as performance part replacements in place for factory original style parts. In this case I'm only consulting factory replacement parts information. Before replacing fuel injectors I'd be inclined to use a good quality fuel supplement to clean them. I'm suggesting this since the replacement of the fuel filter appears to have generated signficant improvement in performance. I would do the cleaning through three tanks full of gasoline with a new bottle of cleaner each time and see if there's any improvement. If the hesitation remained then consider other alternatives to correct it. BTW, have the spark plugs been checked?
Bookmarks |
Tags |
coolant leak, lw200, maintenance, parking brake |
Driver's side windshield moulding issues - 2003 LW200 | tomlct | L-Series General | 2 | 07-29-2020 09:50 AM |
2003 LW200 Spark plug change | linx3566 | L-Series Tech | 4 | 11-02-2009 11:15 AM |
2003 LW200 CD Player | linx3566 | L-Series Tech | 6 | 09-23-2009 12:36 AM |
2003 lw200 | linx3566 | L-Series Tech | 3 | 09-20-2009 10:18 AM |
LW200 oil change | PaulGraz | L-Series General | 3 | 03-26-2005 09:01 PM |
