Old 03-01-2012, 01:35 PM   #1
jake3261
jake3261 is on a distinguished road
2004 L-Series 2.2L Wagon
Default 04 LW200 Problems after starting.
When I start my car, I can hear a ticking noise. This noise continues to happen until I begin to accelerate, then comes back when the car returns to idle(at any speed). Any ideas on something I could check, or what might be wrong?
jake3261 is offline   Reply With Quote
Old 03-01-2012, 03:01 PM   #2
Rebarts
Rebarts is on a distinguished road
Default Re: 04 LW200 Problems after starting.
You're probably going to have to give more info such as mileage, past or recent problems, recent changes, etc...I had the same problem recently and it was the timing chain, but I'm sure more info is needed to diagnose your problem. Any difference in power? Can you tell where the sound is coming from?
Rebarts is offline   Reply With Quote
Old 03-04-2012, 12:07 AM   #3
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
I concur that likely candidates are worn timing chain or stuck timing chain tensioner. If you have over 120,000 miles on the car, it will likely be the chain.
engine, lw200, noise, weird
2002 LW200 - not starting belowme29 L-Series Tech 3 09-04-2011 11:10 PM
Used LW200 possible problems? David R L-Series Tech 9 07-25-2011 09:18 AM
'01 LW200 Not Starting - please help Rbowser4 L-Series Tech 2 02-25-2011 07:53 AM
2001 Saturn LW200 Series intermitting heat Problems kevisca L-Series Tech 5 02-12-2007 03:32 PM
Problems with LW200? notforyou23 L-Series General 10 02-06-2003 09:20 AM
