Old 03-08-2010, 08:34 AM   #1
SovereignDragon
SovereignDragon is on a distinguished road
Default EGR Code Keeps Coming Back
Alright, first I guess I'll introduce the car. Its a 1998 SL2 5 speed with 236xxx on the odometer. I picked it up at 212xxx and have since put on an alternator, water pump, plugs, wires, air filter, coolant temperature sensor (brass), iat sensor, iac, fuel filter, motor mount, dog bone, o2 sensor, pcv valve, tps, and of course regular oil changes. I've also run two bottles of seafoam through the tank and one through the intake. Now on the to the problem. I replaced the EGR valve about 5 months ago. Around two month ago my check engine light came on again and turned out to be the egr. I swapped out the egr valve for a new one (yay warranty) and it was fine. Now it's starting to act as though the valve is getting stuck again and the check engine light comes on randomly. Does anyone have a clue what the underlying problem could be for my egr valves getting stuck. I did notice that when I pulled off the first new one it was disgusting with carbon and all gunked up. Do you guys think cleaning the valve and running more seafoam might help? Someone please help me here. I really love this little car. It's been great to me and even though it's a DOHC it's gotten as high as 45mpg highway in the summertime.
SovereignDragon is offline   Reply With Quote
Old 03-08-2010, 08:46 AM   #2
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default Re: EGR Code Keeps Coming Back
you got an oil burner on your hands dirtying the egr valve.
I used to go thru this myself before dumping ATF into the engine oil.
Now the valve stays clean for a long time.
How is your PCV system working?
sdowney717 is offline   Reply With Quote
Old 03-08-2010, 11:11 AM   #3
What are the codes?
Old 03-09-2010, 08:12 AM   #4
SovereignDragon
Sorry, not only did I forget to grab my scanner from work yesterday but forgot to scan it as well. I'll do that today and get back to you guys on that one.
Old 03-09-2010, 11:30 AM   #5
Tiger
Tiger's Avatar
Even with a new EGR over time chucks of carbon lodged under the pintle on mine. After cleaning it last time I used an EGR gasket that has a screen. No problems for 14,000 miles. Before, I would have problems way before then.
http://www.sherco-auto.com/klean.htm
I also started the car with EGR off to clean things. Car shot up to 4,000 RPM's.
I am going to see how long this lasts and not clean it again until I have problems or codes.
code 26 with lap belt light coming back nmsaty S-Series Tech 6 09-13-2007 11:17 PM
The van is coming back... 4littlemonkeys Relay General 3 09-08-2007 11:53 PM
How-To page is coming back! SQVue Vue General 12 02-22-2004 11:10 PM
One Lap of America - We are coming back Wazz General Saturn Discussion 30 04-25-2001 10:35 PM
