Old 12-02-2021, 12:46 PM   #1
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
Default Driver' s door indicator switch
On a 99 SC2
Where the $#%*& is it?
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-02-2021, 05:48 PM   #2
Default Re: Driver' s door indicator switch
Either on the lower B-Pillar where it belongs, or on the edge of the dash where morons put it. AllData is less than clear about it for '99. It could be covered by a rubber bumper and not look like a switch, or it could just be a plasti-rubber bellows looking thing.
Old 12-02-2021, 06:39 PM   #3
Waiex191
Waiex191's Avatar
The '99 has the little suicide door. Interesting question, where would it go?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-02-2021, 06:49 PM   #4
Just a guess on my part but some common sense and engineering design would put the door switch near the hinged side.
Old 12-02-2021, 09:34 PM   #5
onlinebiker
I have been all over the door opening.. It is not on the side of the dash like a 2001 or 2002. I let it chime as I went all around the door seal. Nothing.
It must be a short stroke switch. The chime will continue with the door closed but not fully latched. It only shuts off after the last 1/2 inch of door travel.
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-02-2021, 10:32 PM   #6
That and finding 2 part numbers for door latch's that say 1999 SC1/SC2 only make it sound like the dome light switch is built into the latch with the optional 3rd door (optional '99-'00, standard '01-'02).
Old 12-02-2021, 10:41 PM   #7
Waiex191
Waiex191's Avatar
Maybe on the thing that keeps the door from opening too far?
Bryan Cotton
Old 12-03-2021, 09:54 AM   #8
onlinebiker
The travel limiter? I thought of that too...
I want to bypass the switch.
If I wanted something to nag at me incessantly - I wouldn't have gotten divorced.....
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-03-2021, 10:24 AM   #9
trottida
trottida's Avatar
Two part numbers makes sense as they made 2 door and 3 door within that model year. From the part photos one appears to be the switch on the lower pillar like my 99 SL2 and the other the switch on the dash end panel. By process of elimination I would think the later but if onlinebiker says it's not there then it's not there. The parts listing must be incorrect.
I did find this post by LowSaturn which states it is integrated into the door latch mechanism. He checked his own car.
Door jamb switch on 1999 SC@
Wow, lots of confusion on this. GM parts listings indicate the dash end panel style switch is correct from 96-02 for all S Series however RichPin's video using his 98 SL2 clearly show it being on the door pillar and it is there on my 99 SL2. I guess the same switch is used for both locations. I thought the dash end panel switch was less beefy.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-06-2021, 02:16 PM   #10
onlinebiker
Fetchitfido gets the cigar for this one... (The guy must get a ton of ' em)..
I found the switch is indeed inside the driver' s door and is actuated by the latch.
So - nice thing about it - anytime you are working with the door open and ignition on - you can pop open the latch thus disabling the chime.....
Thanks FiF and Trottida.. That would have took me forever to find...
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-06-2021, 04:01 PM   #11
Well then common sense and engineering decided not to work for one model year. Must be the new guy getting approval to put the door switch inside the door next to the door latch mechanism. Now I wonder if other models and brands do the same.
Old 12-07-2021, 06:36 PM   #12
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
On my '97 'twas on pillar way far from hinge ... excessive hinge wear
ruined the SW, never worked. I think my 2000 is on end-of-dash. It is less robust, because less relative movement mean less gnashing.
Including SW in the hinge is bordering awesome engineering.
Not surprised that the coupe would be first to incorporate the updated hinge mod --
a very knowledgeable (operating engineer) explained to me that a downside to the
2-door models, was the increased hinge wear, leading to fitment issues (leaks, wind-noise).
ECM Driver/A/C Pressure Switch Codes Chaz9496 L-Series Tech 21 05-15-2020 07:12 PM
Rear defogger switch indicator light inop - 1993 SL2 NWSaturn247 S-Series Tech 2 11-08-2015 07:39 PM
2004 driver door lock switch not working. Gradejohn Ion Tech 0 06-30-2015 08:37 PM
Replace electric door lock switch on drivers door-1999 SW2? Reader S-Series Tech 2 12-04-2010 09:13 PM
Driver side mirrors switch...... txVue Vue General 11 12-03-2003 05:01 PM
