Old 12-01-2022, 02:59 PM   #1
csmolen
csmolen is on a distinguished road
2002 SL1
Question 3rd gen to 2nd gen headlights
I was looking into a new set of headlight assemblies, mine are so yellowed and foggy that it restricts a whole lot of light, and i’ve tried restoration kits and stuff, none of them have worked very well. But, I like the look of the 2nd gen headlights without the orange reflector bit in it, and was curious if 2nd gen assemblies would drop in and work just fine on my 3rd gen SL1
csmolen is offline   Reply With Quote
Old 12-01-2022, 03:32 PM   #2
Waiex191
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
Waiex191's Avatar
Default Re: 3rd gen to 2nd gen headlights
No idea on the swap. When I redo my headlights, I start with 220 wet sandpaper. Then go to 800 and finish sanding with 2000 or something crazy like that. Final pass is the foam pad and polishing compound in a Harbor Freight kit. The rotary sanding stuff in the kit is useless.
Before:
Left light done:
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-02-2022, 12:59 AM   #3
I believe they swap fine 2nd to/from 3rd gen. With the coupes it looks odd if you don't swap the hood as well.
2nd gen, 3rd gen, headlight assembly, headlights
Brake lights work with headlights off, will not brighten with headlights on Highcloudy S-Series Tech 9 09-19-2018 05:14 PM
1ST gen headlights woodroeJ35 Vue General 0 04-28-2009 06:19 PM
Replacing 95' SC1 headlights with 97' SC1 headlights Dreamimage S-Series Mods 1 06-19-2007 03:55 PM
Different 06 Vue Headlights BradJK Vue General 2 08-02-2005 08:23 AM
