Old 03-30-2018, 10:59 PM   #1
terminal89
terminal89 is on a distinguished road
Default How to switch from Lucas additive + conventional back to synthetic
Hey I used wolfman's reverse slam fix. In it he specifies conventional fluid as he says transmission additives do not mix well with synthetic fluid which is loaded with add packs.
I had the best shifting with mobil 1 ATF by far. I want to go back now that reverse slam issue is fixed. How do I go about this and ensure lucas slip additive does not screw me.
terminal89 is offline   Reply With Quote
Old 03-31-2018, 04:24 PM   #2
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
Default Re: How to switch from Lucas additive + conventional back to synthetic
Just drain and refill with the new fluid. You can do it again later if you want to get more of the old out. What's left in it will be fine. I also use the Mobil 1 atf and agree that it shifts well.
Cheyne is offline   Reply With Quote
Old 03-31-2018, 07:15 PM   #3
Originally Posted by Cheyne View Post
Just drain and refill with the new fluid. You can do it again later if you want to get more of the old out. .
Somewhere on here, there are calculations on what percent of old /new fluid there is at each ATF change.
Old 03-31-2018, 07:56 PM   #4
Cheyne
2000 SL2
I remember reading a thread about that a number of years ago. I ended up doing three changes in switching mine to synthetic that IIRC may have been derived from it. OP could do the same by adding one more to the above. He'll probably be able to judge the need by the shifting after the second change since the Mobil 1 was in there before the slam treatment.
Old 03-31-2018, 10:43 PM   #5
Saturn Night
Band-Aid on a Bullet Wound scenario.
Switching back to synthetic will allow the reverse slam to come back. It will take a little bit of time and driving, but the slamming/delay will come back, as the synthetic ATF dilutes the remaining Lucas additive left in the transmission.
The reverse slam occurs, because the steel seals have bored out the cast aluminum valve body bore for the boost pressure valve.
Adding the Lucas causes the viscosity and thickness of ATF to increase, which allows a temporary increase in line pressure to the clutches. The viscosity increase can also allow slipping clutches to grab again, temporarily.
The ATF gets thickened because the Lucas has pure petroleum in it, which is the base stock of any lubricant.
Your valve body needs to be replaced, to correctly fix the problem.
Contact Special Forces, a member on here.
He specializes in the boost pressure valve bore and has over 10yrs of experience with rebuilding these valve body assemblies.
200k miles on my 1996 Saturn SL1, should I switch back to conventional oil from synth machead90 S-Series Tech 11 02-21-2012 01:12 PM
ATF synthetic vs conventional. jaekl S-Series Tech 14 07-15-2009 03:16 AM
Removal of Lucas additive from transmission TrikLogistics S-Series General 11 03-05-2009 10:45 PM
Mixing synthetic and conventional oil? wolfehunter S-Series General 18 02-02-2009 11:29 AM
Conventional to Synthetic results 01SL1SATURN S-Series General 18 12-27-2007 05:49 PM
