Old 03-17-2018, 05:00 AM   #1
Commeatus
Commeatus is on a distinguished road
1998 SW2
1997 SW2
Default wagon rear seat swap questions
First, apparently the 1st gen wagon rear seats fold flat. true?
Second, can I reasonably swap them into my gen2? I'm pretty handy but I don't have access to a grinder/metalworking tools.
I dug deep in the search results but I can't find answers. Thanks!
Commeatus is offline   Reply With Quote
Old 03-17-2018, 10:05 AM   #2
Default Re: wagon rear seat swap questions
The S-Series never had fold flat seats. They fold down sure, but not flat or anywhere near flat.
Old 03-17-2018, 03:08 PM   #3
Commeatus
1998 SW2
1997 SW2
I got my hopes up
I'd still be interested in getting rid of the bar on the seatbacks: I spend a lot of time hauling stuff and the flexibility of independent seats would be a lifesaver. I'm usually driving with the rears folded anyway so the side-impact safety is moot. do the seatbacks interchange?
Old 03-17-2018, 03:26 PM   #4
The latch is in a different place on the sedan seat-backs than the wagons, the bottoms are identical.
I don't remember a bar behind the seat backs on a '97 SW2 but I found out real freaking quick the useable extra cargo room is just as fake as the flat-folding rear seats and effectively traded it in for a "smaller" Impreza 2.5TS that actually had more cargo room.
Old 03-17-2018, 04:37 PM   #5
Commeatus
1998 SW2
1997 SW2
my old 97 sw2 had the bar, as does my current 98.
to better phrase my question, are all generations of wagon rear seatbacks interchangeable? is there any weirdness needed to drop gen1 wagon seatbacks into a gen2 wagon? no sedans or coupes involved.
Old 03-17-2018, 06:49 PM   #6
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
I may not be remembering this correctly but if you never plan on actually using the back seats, I'm pretty sure that if you remove the cushion that you sit on it will allow the back to fold down flat, or at least closer to flat
97 SL2, auto, 123K miles
Old 03-18-2018, 03:06 AM   #7
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
"I'm pretty sure that if you remove the cushion that you sit on it will allow the back to fold down flat, or at least closer to flat"
'96 SW2 MT
I've considered going that route but never got around to trying it. Other than the fact that I've just procrastinated doing it, another reason I never tried is that I don't know how much road noise damping the rear cushion provides. With my luck the seat backs would fold flat but the trade-off would be that cabin noise would be noisier than the dickens.
Mister_Cee is offline   Reply With Quote
Old 03-19-2018, 04:32 AM   #8
Commeatus
1998 SW2
1997 SW2
Yeah, without the seat cushion it's close enough to flat but I can't give up the utility. I found a gen1 wagon in my local pick n pull (it might be the same gen1 I pulled the valve cover gasket from a few weeks ago!) so I'll spend some quality time with its seats when I get a chance and report back. Wish me luck!
Old 03-19-2018, 09:58 AM   #9
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
I'd really like to know if that works as well, keep us posted!
http://www.youtube.com/velocitylabs
ErikTande is offline   Reply With Quote
Old 03-20-2018, 01:50 PM   #10
Check out hein's 2nd gen "shaggin' wagon"
http://www.saturnfans.com/forums/sho...d.php?t=156776
you can use reflectix or carpet padding for sound insulation, if needed
Old 03-22-2018, 12:06 AM   #11
Commeatus
1998 SW2
1997 SW2
Swap complete! all wagon rear seatbacks seem to be more or less interchangeable.
The specifics: gen2/3 seatbacks have bracing pegs on either side that block gen1 seats and must be unscrewed with a t50 torx.
the gen1 seats use a long metal peg with a plastic clip to secure them near the doors. the gen2/3 pegs are much shorter. you can use the gen1 pegs but it's a real hassle. all the pegs unscrew with a t30 torx.
the gen1 seats are around 2 inches thinner towards the top and although they don't fold completely flat, they're noticeably closer to level!
other than that, it was pretty painless! thanks for the help, everyone, and the pics from the swaggin wagon thread were actually pretty helpful.
Old 03-22-2018, 08:00 PM   #12
hholbein
1997 SW2
I have a 1997 SW2 and it has that goofy brace between the two seats. I believe that brace was also related to meeting some federal standards for reducing side impact incursion and stiffness for 1997+ model years. I think there are also some metal pins in the door that mate with the door frame as part of the changes.
Anyway, that brace is a real kludge job, it squeaks a lot and is balky to operate.
If you could post some pictures of your swap and the latch/peg replacements, that would be nice!!!!
Old 03-23-2018, 01:21 AM   #13
ErikTande
ErikTande's Avatar
Pics!
Old 03-29-2018, 04:32 PM   #14
Commeatus
1998 SW2
1997 SW2
Three more posts and I'll link an album!
Old 03-29-2018, 04:34 PM   #15
Commeatus
1998 SW2
1997 SW2
Almost there!
Old 03-29-2018, 04:37 PM   #16
Commeatus
1998 SW2
1997 SW2
Pics next post
Old 03-29-2018, 04:39 PM   #17
Commeatus
1998 SW2
1997 SW2
https://www.facebook.com/media/set/?...1&l=78f1ecf333
Old 03-30-2018, 03:15 PM   #18
Very cool, thanks!
Old 03-30-2018, 05:45 PM   #19
ErikTande
ErikTande's Avatar
Wow that's awesome, thanks for the pics. I need to find a gen1 wagon now!
Old 03-30-2018, 09:58 PM   #20
ErikTande
ErikTande's Avatar
So you just swapped the backs, not the bottom, right?
Tags
rear seat, swap, wagon
Shaggin Wagon, 98SW raised floor (rear seat delete) hein S-Series Mods 66 02-26-2019 07:05 PM
LW300 station wagon rear seat jingles wdfsilverbullet L-Series Tech 0 09-21-2010 09:15 PM
Rear seat swap? Av8r S-Series Tech 3 03-22-2005 11:50 AM
First gen SC2 rear seat swap for an SL2? Tuanies S-Series Mods 7 11-20-2002 11:20 PM
Rear Seat Swap SpeedSW2K1 S-Series Mods 3 03-12-2002 01:05 PM
