Old 02-06-2010, 12:03 AM   #1
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
Default MP7 Transmission Swapping
I'm going to be buying a valve body from Special Forces, regardless of if that'll fix the transmission issue or not (I figure I can throw it in the new transmission if thats the case, less worry!)
Anyway, if that doesn't turn out to be the issue, I was doing some reading today, and was curious about the gear ratios, and the PCM getting confused and throwing a check engine light because the ratios don't match the original transmission.
The car is a 1998, but has a birthday of 10/97, so I figure it's safe to guess it has a 1997 brain.
Copied from Different Racing:
1991-1997
MP7 Gear Ratio
1st Gear - 2.53
2nd Gear - 1.56
3rd Gear - 1.03
4th Gear - 0.70
Reverse - 2.39
Final Drive - 4.133
Automatic Transmission 1998-2002
1998-2002
MP7 Gear Ratios
1st Gear - 2.53
2nd Gear - 1.56
3rd Gear - 1.03
4th Gear - 0.70
Reverse - 1.91
Final Drive 4.063
I can see that 1, 2, 3, and 4 are all the same from 1991 to 2002, but reverse is different, and so is the final drive. What I want to know is; first, I have a 1995 transmission in my car right now, which I believe to be a replacement.
If I have to get down and dirty and replace the transmission, does this mean I'm limited to 1991 to 1997 only? or can I use any MP7 automatic and the PCM won't care, and will be able to shift though all the gears? I have a 1998, but it was made in 1997.
I'm confused, could someone PLEASE explain this to me before I have to go out and get my hands dirty for nothing?
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
KingRex is offline   Reply With Quote
Old 02-06-2010, 12:19 AM   #2
KingRex
KingRex's Avatar
Default Re: MP7 Transmission Swapping
Also, to add in, if there is an issue with the TCC and the ratios for 1998 and such, what if I just grabbed a PCM from a 1997 or 1996 and used that? Nothing really says much about the cars PCM. I have a very base SL2, no cruise, no power anything.
Any input on brain swapping? It would be easier, I can get PCM's all day long for free.
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
swapping out the vti plastikvue Vue Tech 5 01-17-2010 10:11 PM
shifting problems after swapping auto transmission woodsculptor S-Series Tech 3 06-27-2009 11:47 AM
transmission swapping packerfan S-Series Tech 10 02-25-2008 11:14 AM
swapping 95 TB onto a 96 sps SOHC S-Series Tech 9 11-24-2005 11:12 AM
PCM Swapping is it possible? SlimSaturn Miscellaneous Tech 1 12-16-2002 05:52 PM
