Old 02-23-2008, 08:44 PM   #1
packerfan
packerfan is on a distinguished road
Default transmission swapping
I recently order a used transmission to have changed out on my 2000 Sl1 Sohc. After using the vin number on car fax for the on I ordered I learned it was coming off a 1998 Sl2 Dohc. Are these two trany's interchaneable?
packerfan is offline   Reply With Quote
Old 02-23-2008, 09:49 PM   #2
rc1488
rc1488's Avatar
Default Re: transmission swapping
If an automatic...no. If manual, yes but CC wont work
Old 02-24-2008, 10:01 AM   #3
kim_lombard
kim_lombard will become famous soon enough
NO, the gear ratios are different. The PCM won't shift it correctly. One of our members has been kind enough to post them to show the different gear ratios.
http://www.differentracing.com/tech_...gearratio.html
you need to make sure that donor transmission is from a SOHC. there is a identification number stamped on the bell housing that identifies the type of transmission.
kim_lombard is offline   Reply With Quote
Old 02-24-2008, 01:41 PM   #4
rc1488
rc1488's Avatar
If they are automatics, then yes you are completely right. Gear ratios dont match and the SOHC PCM wont know what to do or when to shift. The DOHC PCM would need to be brought over with the DOHC tranny.
However, if they are manuals, then it will work regardless of the PCM. The PCM does not care about shift points or anything on the tranny. The Cruise Control however will not work bc its based of the SOHC gear ratios. Other than that, it should work fine. A DOHC cluster would be nice but ive read of people using the SOHC cluster just fine
Old 02-24-2008, 04:27 PM   #5
asdf
asdf is on a distinguished road
Well, the PCM in the manual does know all the gear's ratios. The shift light would be off, and like you said, the cruise control, which is the PCM, won't work.
asdf is offline   Reply With Quote
Old 02-24-2008, 10:11 PM   #6
rc1488
rc1488's Avatar
It knows yes, but does it care ?? As in will it set the SES light off bc of them
Old 02-24-2008, 10:15 PM   #7
packerfan
So what your saying is if I get a DOHC PCM computer for my 2000 SL1 and it will handle a DOCH tranny? Does it have to be a 2000 PCM or does it have to be the same year computer as the Trany itself?
Old 02-24-2008, 10:23 PM   #8
rc1488
rc1488's Avatar
Depends if you have an automatic or a manual.
If an automatic you need a 2000 DOHC PCM with the same options as your car. LowSaturn will correct me if im wrong
Old 02-24-2008, 11:49 PM   #9
asdf
Fortunately, in your case, the PCM is only different between the auto and manual. What you will be able to do is get your car programmed at a dealership.
Old 02-25-2008, 01:02 AM   #10
rc1488
rc1488's Avatar
and spend tons of $$$$. Junkyard is best
Old 02-25-2008, 11:14 AM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
It will work for the transmission but not the engine. Unless you're planning on doing a DOHC swap too.
A 1998 automatic transmision out of a DOHC vehicle simply will not work in a 2000 SOHC. If your car is an anutomatic and the tranny is on its way, you just bought a nice big paper weight.
You really need to let us know what kind of transmission it is to get the best answer, otherwise we're all just wasting our time with speculation.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Tire swapping trottida S-Series Tech 2 10-14-2009 09:47 AM
shifting problems after swapping auto transmission woodsculptor S-Series Tech 3 06-27-2009 11:47 AM
swapping 95 TB onto a 96 sps SOHC S-Series Tech 9 11-24-2005 11:12 AM
swapping clusters!!! mtlmutt Ion General 19 02-17-2004 10:08 PM
Seat swapping Mr Mike Miscellaneous Tech 1 10-03-2002 09:49 AM
