#1 |
![]() Join Date: Aug 2006
We recently purchased a seconfd Saturn. This one is a 50,000 mile one owner 2001 SC2. Both headlights assemblies contain water droplets. I cannot see any visible cracks. I did check with the local Saturn dealer and I was told this is a common problem. Replacement units are $209 each. I contacted the Saturn manufacturers website, and their customer service group replied that they are not technical people, and would not send the question / complaint to the factory. What needs to be done to remove the water, and seal these units.
#2 |
![]() ![]() Join Date: Jan 2006
2002 SC1
There should be a drain/vent hole in the headlights. Usually it was done at the factory, but sometimes it was done at the dealer. Check for a drain hole and make sure it's not blocked. If there is no hole (I believe it's somewhere at the bottom) I can take a look at mine and tel you where it's at.
Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy. |
#3 | |
![]() Join Date: Mar 2006
![]() Quote:
![]() As for your newer car having droplets, since the these are not truly sealed bulbs (The replacement tiny sealed bulb has a gasket to seal it into the larger reflector) your bulb may not be cracked or otherwise breached. Avoiding temperature fluctuations and humidity are the only way to completely avoid this (Have a heated garage in an arid climate)! ![]() |
#4 |
I posted the question that started this thread. I just looked inot the archives and found that someone had mentioned a recall on 2001 SC2 headlight assemblies related to water build-up. Does anyone know anything about this?
#5 | |
2002 SC1
![]() Quote:
#6 |
I did stop at the dealership the other night, and spoke with the service writer. He ran the vin number and no recall notices apply to the car. He said there is avent tube in these 2001-2002-??? headlight assemblies, but off-hand he could not remember where. Being it was late in the day and they were closing we did not have time to pull a new part of the shelf. I looked in their used car lot and service parking area, and there were no 2001-2002-??? model SC-2 vehicles to look at. Any ideas?
#7 |
2002 SC1
I've got an '02 and so far no condensation. I'll see if I can take a look at mine when I get a chance today, and let you know exactly where it is.
#8 |
![]() ![]() ![]() Join Date: Jun 2004
ah yes, the water in the headlights problem i know it well. i had one headlamp replaced & the other twice because of this problem. also both back-up lights for the same problem. there's no recall on this problem, just a bulletin on the guidelines regarding when replacement is necessary. they are replaced when you see actual droplets of water in the lights & some in the bottom of the lights. light fog is normal at times which drys up promptly. the reason why this happens is the white glue/caulk that the factory uses to assemble these light assemblies tends to dry out over time & crack mostly from bulb heat & just time causing leaks in the housings. this is the main problem causing water entrance in the lights. actually any car with these type of lights are prone to the same problem because they use the same adhesive. you can use some epoxy glue to seal them up, or some caulk, but these fixes tend to be short lived as those adhesives also tend to fail in a short period of time. we have a 2001 malibu which has the same problem & i epoxy the one leaking light. it lasted a few months & leaked again. replacement of the lights seems to work best for me. i seen saturn aftermarket lights available on various sites for about half what saturn wants for theirs. don't know the quality level of these lights though, but ya usually get what you pay for in this world. if they would plastic weld the units together this would eliminate this problem, but then they can't make money on selling replacements....
#9 | |
![]() Quote:
Bookmarks |
an update on the 2001 SC2 headlight water | greencoupe02 | S-Series General | 6 | 09-23-2011 12:41 AM |
SC2 Water in headlights | IVIYTH0S | S-Series Tech | 8 | 09-15-2009 04:57 AM |
2001 SC2 Water pump? | between5and7 | S-Series Tech | 5 | 05-21-2007 09:35 PM |
2001 sc2 headlights ( replacement bulbs ) | jaason1 | S-Series General | 5 | 09-24-2006 12:55 AM |
vent tube in 2001-2002 SC2 headlights | greencoupe02 | S-Series General | 9 | 08-12-2006 01:32 AM |
