Old 01-29-2022, 01:54 PM   #1
Sarao
Sarao is on a distinguished road
Wrench 08 Outlook loud clicking knocking sound
My 2007 Saturn Outlook started making a knocking sound after replacing pcv valve and doing a tune up. I tried replacing cam shaft sensors because thats the error that came up but the noise has not stopped. It is a loud clicking knocking sound it came on suddenly so i dont think the issue is the motor but I have not been able to solve it.
Sarao is offline   Reply With Quote
Old 03-14-2022, 12:59 AM   #2
pierrot
pierrot's Avatar
Default Re: 08 Outlook loud clicking knocking sound
Apparently you've not received any greeting from a member here so...
Welcome to SaturnFans, Sarao!
Making a repair based upon too little information can result in no change having been effected as has happened here. What was the original Diagnostic Trouble Code number? It would've been a "P" followed by four numbers (example - P0301).
The suddenness with which a noise emanates from somewhere under the hood tells neither you nor the professional that it is unrelated to the engine. It could actually be coming from somewhere within it. The only certain thing is that there simply isn't enough information to confirm this either way so it's best not to presume anything.
Where does this noise seem to be coming from? Is it nearer to the cylinder heads? Is it beneath them and sounding like it comes from the engine block? What is the maintenance history of this vehicle?
374K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?!
Old 06-30-2022, 02:28 AM   #3
netgil
netgil is on a distinguished road
It's always best to see an expert if you're experiencing severe hair loss but you can never underestimate the magic of a good quality shampoo either. So, if you are searching for the top 10 best hair fall shampoo in india check it.
netgil is offline   Reply With Quote
Turning left Loud Clicking sound. RGodwin S-Series Tech 5 08-28-2015 06:23 PM
Spark knocking or egr clicking? sat2urnsc2 S-Series Tech 1 02-22-2010 12:02 AM
Knocking/clicking sound & oil problem ns087 S-Series Tech 11 10-30-2007 02:12 PM
Loud clicking sound SPman00 S-Series General 3 11-10-2006 10:43 PM
Loud Knocking Noise flannelenamel S-Series Tech 2 08-13-2006 09:41 PM
