#1 |
![]() ![]() ![]() ![]() Join Date: Mar 2015
Sorry again if this has been in another tread, which I assume it has. I thought the condenser fan was supposed to pull air in. Mine pushes out from the condenser to the front. That would fight the air trying to get in. Anyway, seems backward. As stated in other posts of mine, my phone won't search the Forums for some reason. Thanks.
#2 |
Our 3.0L V6 engines use two cooling fans; looking into the front grille - left side fan in front of condenser coil should force air into the c-coil/radiator, right side fan behind the radiator pulls air thru c-coil/radiator. Service manual descriptions use terms pusher and puller. Parts descriptions may use these two terms to ensure ordering the correct replacement.
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2015
2002 L-Series 2.2L Sedan
The 4 cylinder L series cars have the same fans as the v6 cars. Fdryer has described the system correctly.
2002 L200/5 Loaded, over 1/4 million miles! |
#4 |
How is there a Left Side, Right Side looking from the front ? I have a Front, and Rear.
#5 |
Ok, left front fan in front of c-coil blows air thru, right rear fan pulls air.
#6 | |
![]() Quote:
374K miles - Holy canolli! Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?! |
Bookmarks |
New guy needs pointed in right direction. | ferret7824 | Ion Tech | 22 | 04-04-2018 07:16 PM |
Need some direction from the Pros | oakraiders24 | S-Series Tech | 33 | 12-17-2010 06:38 PM |
A Little Direction- | BigJonCA | S-Series Tech | 8 | 11-28-2009 08:22 AM |
Need direction! | cbea1124 | L-Series Tech | 0 | 12-28-2006 03:28 PM |
93 SL2 woes... need some direction | 03zq8 | S-Series General | 13 | 02-18-2004 03:19 AM |
