#1 |
![]() Join Date: Feb 2011
I have a Saturn SL1 1999 it has 164K on it. My front rotors are in need of
turning. There is a little warp feeling when braking at low speed. Not too bad. At high speed, braking causes a lot of vibration. I was told garages don't turn brakes any more. I am hoping i can just go and buy the new rotors and have a garage put them on. I don't want to put new brake pad on either. Does anyone know if that is do able. ?? |
#2 |
![]() ![]() Join Date: Nov 2005
1996 SL1
Check out rockauto.com
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2011
2002 SC1
Changing the rotors while re-using pads is not elegant, but it can be done. Brfaking might be diminished slightly until the pads wear enough to match the flat surface of the new rotors. However, if you are using semi-metallic pads, these can be the source of the vibration. Use only ceramic pads on these cars.
BV22 2002 SC1 5M RIP Sept 1 2018 315,344 miles |
#4 |
![]() Join Date: Jan 2012
1994 SW1
2000 SW2
Chances are that your caliper pins are frozen. This generally leads to uneven wear on the pads and rotors, hence the vibration. This is not the place to be cutting corners, and most shops won't participate in substandard brake repair for obvious liability reasons. You will most likely have to replace rotors, pads, pins and clips. Better to bite the bullet and do it right the first time.
97 sl2 a/t 104 K 1989 GMC 3500 454 129 K, 1969 442 455 rat rod |
#5 |
![]() Join Date: Sep 2013
1993 SC2
In my area, almost all O'Reilly Auto Parts stores (about 15 in a 20 mile radius) will turn rotors for $15 each, and any GM dealership would be able to do it for you too. As a former worker at O'reilly I remember in training that majority of the stores offer Brake Rotor/Drum/Flywheel turning/resurfacing
#6 |
Turning the rotors for $15. Or buy new at $12. http://www.rockauto.com/catalog/more...286&cc=1317283
May not fix the original problem with the brakes. |
#7 |
![]() ![]() ![]() ![]() Join Date: May 2008
2004 VUE 2.2L
Turning modern rotors is a total waste of time and $$$. There isn't enough metal on/in them to turn them effectively. Make sure the calipers are working correctly, get rid of all corrosion on the hub, inside the rotor, and wheel mating surfaces, give all bare metal a thin coat of high temp grease, use proper torque when reinstalling the wheels. Rotors will last until brake pads wear out. When they do replace rotors and pads again. They are too cheap to buy to reuse
2006 Toyota Highlander (rare 4 cyl AWD) 2001 Toyota Highlander V6 AWD creampuff Daughter got her own! 2005 Lexus ES330 Dream Ride |
#8 |
![]() Join Date: Oct 2013
1995 SL2
1993 SW2
I've turned my rotors with no problem. I know rotors are cheap but its because they're cheaply made. I had problems with replacement rotors on my Taurus.
BV22, Why should only ceramic pads be used? If you aren't mechanically inclined, just get new rotors and new pads. |
#9 |
NAPA also turns them...
#10 |
2002 SC1
First, because that is what Saturn used. Second, for FWD cars in general, the majority of braking is done by the front wheels, generating a lot of heat. Many of the store brand semi-metallic pads do not hold up well to the heat, resulting in pad transfer to the rotor surface when sitting still after a hard, long stop. This transferred pad material leaves "sticky" spots on the rotors, resulting in the pulsation and vibration often associated with warped rotors. I've experienced this first hand, having used semi metallic pads once on new rotors. Within several thousand miles, hitting the brakes at 70 mph was frightening. Since the rotors were relatively new, I changed the pads with ceramics, cleaned and lubed pins, and put it back together with the existing rotors. In a matter of weeks, the new ceramic pads had wiped the rotors clean, and a year later, I can still haul the car down quickly from freeway speeds without any jiggles.
#11 |
![]() Join Date: Sep 2005
Ceramic pads are not necessary but recommended. I also use them as well. There are benefits from using them such as lower dust levels, less apparent brake fade at higher temperatures and longer pad wear intervals.
Both can be noisy depending on the blend used to make the pads but ceramic pads are usually quieter in my experience. I usually change both pads and rotors at the same time as standard rotors are not expensive. I am using Ate Premium One which are grooved or slotted and have been happy with them using ceramic pads. With the cost of standard rotors so reasonable, I have never turned/machined rotors on my Saturn. Not worth the expense in my opinion for an S-Series. |
#12 |
Thanks all !! I will pick up new rotors and pads. I am having a garage
do it cause it is getting too cold out for this driveway mechanic. ![]() |
#13 | |
1995 SL2
1993 SW2
Thank you. Thats some very good information. I never knew any benefits for ceramic pads. Since my Taurus is super sensitive, I'll try them when the vibration returns.
Interesting that you say the ceramic pads will "clean" the rotors. Quote:
#14 |
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2001
OldNuc recommends Centric brand rotors, part #12062038, available from rockauto or amazon.com. I installed a set and have been very pleased with them so far. They're worth the extra $10 per rotor versus the white-box Chinese rotors.
'95 SL1 auto (RIP) '98 SL2 5sp (RIP) '01 SL2 auto (RIP) '99 SC1 auto (RIP) |
#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2011
2001 SL2
![]() Quote:
#16 | |
2004 VUE 2.2L
![]() Quote:
#17 |
2001 SL2
mostly due to previous poorly trained techs who can't read a mic and that more is better and faster on a lathe...i have got 3 brake job cut on mmy sl2's roters..needed every 2yrs as i live on a 55%grade hill thats about 2 miles long and the old blister is hard on the pads with jack rabbit starts and stops
#18 |
^ I would agree with you except for the relatively low cost rotors and drums, wherever they're made, that compete with brake shops that still use brake lathes. As you know, there was a time when it was cost effective to turn rotors and drums before imported brake parts flooded the market with low cost replacements. As a first time user of white box rotors, I have absolutely no problems with braking and can justify replacement instead of machining rotors. The difference in cost is about $10-$15 so anyone that lives from pay check to pay check can reuse worn rotors/drums as long as they still have meat on them and not result in less minimum thickness/larger diameter (drums) after machining. The trend away from people that can operate a brake lathe may be due to the 'joystick' generation of men and women that see computers as a clean way of living. Without any ability to satisfy a growing curiosity in things mechanical, 'joystick' generations never touching a screwdriver around the house learn later what's required for car maintenance.
I'm amused that anyone knows what a micrometer is and how its used.............
VCX NANO |
#19 |
![]() ![]() ![]() Join Date: Apr 2009
I beg to differ. we were taught how to read mikes in both brakes and engine repair class...
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
#20 | |
2004 VUE 2.2L
![]() Quote:
But that was in the day when brake rotors had materiel enough to true them up and so on. Today that is not the case. The actual thickness of the materiel that can be machined is so thin that once brakes have gone 40, 50 or more K you're getting in to the porous portions or will so soon it is not economically worth it to machine them. There are exceptions. I recently bought a Camry. It still has the OEM rotors at 175K. And they are very heavy and thick. There is a lot of material there to machine if I should have to. But the tiny little thin rotors on so many other cars? Forget it. Especially Saturns
Bookmarks |
Converting rear drum brakes to disc brakes | Sliverstreak02 | Vue Red Line | 17 | 03-19-2016 06:10 PM |
Front Brakes vs Rear Brakes? Saturn S-series | EvanVanVan | S-Series Tech | 25 | 11-14-2011 09:39 PM |
Car turning off when I hit the brakes?? | needanewcar | S-Series Tech | 15 | 09-01-2010 08:14 PM |
Hard brakes, Climb in rpm when brakes applied | motodan | S-Series Tech | 7 | 05-17-2010 10:22 PM |
Problem with engine turning on then turning off, everything is on radio, lights, air | fatimaknapp | Ion Tech | 6 | 12-28-2006 05:02 PM |
