Old 11-14-2013, 05:00 PM   #1
chris015
chris015 is on a distinguished road
Default low temp gauge.
Welp,been fixing my brothers sl2 (00' dohc) today. his temp gauge barely moves. has hot heat. i replaced the stat. Old one didnt have the seal on the base. i thought since it didnt (its been replaced by previous owner) water was getting through and never letting the engine warm up. Well,that didnt fix it.
So i went ahead and got a ects for it. Swapped it out and the gauge now moves from the center before the first mark to right under it. I did notice the pigtail was green and corroded. Im guessing thats my next step? checked pricing...40 bucks? From another search did i found guy saying the iat plug would work. just had different colored wires. If so il grab one at the pick it yard later.
chris015 is offline   Reply With Quote
Old 11-14-2013, 05:03 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: low temp gauge.
From what I've read, you are on the right track. I've never had to mess with my ECTS, since it is a 2002.
As of 11/12/20: 78,895 Miles
Old 11-14-2013, 05:06 PM   #3
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
If the connector is corroded it will need to be replaced, solder and heat shrink the new connector onto the harness, If you want to try some brake cleaner to clean the connection it might help but in all reality if the connector is coolant ridden it needs to be replaced....
CHECK YOUR OIL!
Old 11-14-2013, 05:09 PM   #4
chris015
ive got some mass air flow cleaner. I wonder if thats the same as electrical contact cleaner?
Old 11-14-2013, 05:16 PM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
You can try that it might help it might not you dont have much to loose....
CHECK YOUR OIL!
Old 11-14-2013, 05:45 PM   #6
chris015
it'll have to be later. im tired of burning my hand on the egr lol.
Old 11-19-2013, 05:04 PM   #7
adventureoflink
adventureoflink's Avatar
and this is where a pair of those welder's gloves or some gauntlets would work...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 09:07 PM
Temp Gauge lenmcdade S-Series Tech 4 05-03-2011 01:03 PM
temp gauge:is this right? Melissa_M S-Series Tech 4 07-25-2008 11:19 PM
Help: Temp Gauge Philly Assassin S-Series General 10 08-04-2006 12:54 AM
Vue Temp Gauge tbl01 Vue General 3 11-19-2002 09:14 AM
