Old 11-13-2011, 10:54 PM   #1
saturn/chev
saturn/chev is on a distinguished road
Default check engine light and coolant level light stuck on
I was having issues with erratic idle bucking and cooling fan not coming on. I read some other threads that suggested changing TPS which I did to no avail. So I changed the ECTS and Idle settled down to normal but the engine check light and coolant level light came on solid and wont go off. The bucking thing is still going on. Still cant tell if fan comes on since weather is cooler now.
Any suggestions would be appreciated.
1993 Sl-1 1.9 single cam 102,000 miles.
saturn/chev is offline   Reply With Quote
Old 11-13-2011, 11:08 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: check engine light and coolant level light stuck on
what codes are you getting? search for paper clip to learn how to read codes from your car -- seriously.
If this is anything like OBD-2 (where if the ECTS is not present the SES and hot/low coolant lamps stay on all time time, bonus points if the gauge pegs to the 1/2 line all the time), I would start with the ECTS connector wiring. Check for corrosion, loose/broken connections, etc...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 11-14-2011, 08:47 PM   #3
saturn/chev
could someone explain how to get the codes from my 1993 SL-1?
Old 11-14-2011, 09:36 PM   #4
saturn/chev
okay I got the codes 14,26,32.
Old 11-14-2011, 10:46 PM   #5
adventureoflink
Was the SES blinking for the codes or did the coolant light get involved too? SES blinking means engine codes; coolant light blinking means transaxle codes. Either way..
code 14:
engine: Engine coolant temp. circuit. Temp. out of range high (most likely source of your SES+coolant lamp on 100% of the time; so it IS like OBD-2 vehicles...)
transaxle: Line pressure low (1993 & 1994 vehicles)
code 26:
engine: Quad Driver output fault
transaxle: TCC stuck on
code 32:
engine: EGR system fault
transaxle: Transaxle temperature circuit grounded (hot)
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 11-14-2011, 10:48 PM   #6
regenoldiii
regenoldiii is on a distinguished road
regenoldiii's Avatar
1995 SC1
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
The 32 EGR is easy enough. You can try cleaning it (search YouTube for RichPin Saturn EGR video) and you should get a step-by-step cleaning procedure. Worse comes to worse and it's really hosed, then it's an easy change, but fairly expensive @ about $100 at local parts store (maybe cheaper at Rock Auto, though).
I'll let someone else comment on the other codes. I'd have to google Quad Driver Output Fault... never even heard of that one.
Vehicles:
'95 Saturn SC1 (single owner)
'99 Mustang GT (sold)
'09 Toyota RAV Sport
'09 BMW 135i
regenoldiii is offline   Reply With Quote
Old 11-14-2011, 10:49 PM   #7
adventureoflink
Reggie, here's the quad driver:
http://www.differentracing.com/tech_...es/dtc/26.html
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 11-15-2011, 08:02 PM   #8
saturn/chev
"Temp. out of range high" what exactly does that mean?
Old 11-15-2011, 11:50 PM   #9
adventureoflink
http://www.differentracing.com/tech_...es/dtc/14.html
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 11-16-2011, 01:14 AM   #10
Make sure you got an ECTS and not a gauge sender. A gauge sender has the two terminals ganged together, which, when mistakenly commissioned as an ECTS, puts zero resistance between the terminals going to the PCM, which translates to an out-of-range high temperature.
Either that or the connector is fouled, and is shorting between the two terminals.
BTW, this must be an automatic car, right? The coolant light goes on STEADY when the PCM sees a disparity between the engine temp and the tranny temp (automatic only).
Old 11-16-2011, 09:31 AM   #11
saturn/chev
is there a visible difference between senders they look the same to me and yes my vehicle is automatic no temp lights flashing when checking codes just engine light
Old 11-16-2011, 10:35 AM   #12
I'm guessing the "?" key on your keyboard is on the fritz, and that there's a question in there ^^^^^ somewhere. There's a very subtle difference between the connectors of the two sensors; it's supposed to keep you from plugging the wrong wiring connector into the wrong sender/sensor. But you'd never know it just looking at it, and the "interlock" doesn't really work; it's easy to plug the wrong one in. Best option would be to go by part number.
Old 11-16-2011, 12:09 PM   #13
saturn/chev
Im a lazy typer.
Old 11-22-2011, 09:20 PM   #14
saturn/chev
Well all the work is done car runs great! Thanks to all for your suggestions
and tips. I couldn't have done it without all the input. Recap I replaced ECTS to cure RPM issues and fan not coming on when hot. Replaced EGR solenoid - cured
the low RPM stall and engine light and error codes. Replaced EGR valve - cured the mid range bucking.
Thanks to all
and Happy Holidays
03 L300 low coolant level light on intermitently level is fine wooskie L-Series General 16 03-27-2010 05:26 PM
Coolant light coming on but coolant level is fine. Help? Writerbecky12 Ion Tech 9 06-21-2008 03:11 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 12:56 PM
Coolant light and coolant level light flash after gunning it? FightingChance S-Series Tech 7 10-07-2006 11:03 PM
Intermitant coolant temp. and coolant level light? speedy45 Miscellaneous Tech 1 11-01-2001 08:40 PM
