Old 02-16-2021, 12:40 PM   #1
C. Gadda
C. Gadda is on a distinguished road
Default Minor Washer pump dilemma
Been having issues with my windshield washer. Neither nozzle was spraying very well, or at all. I had my mechanic blow out the tubing, which improved matters but did not restore 100% functionality. Note that the pump runs, but I suspect it is not at 100% new efficiency (this is the original pump on a 95 SC2) I've gone ahead and purchased a new pump which brings me to my dilemma.
The replacement pump has a different connection, which requires me to splice in new wiring. I can certainly do that, but since I'm not 100% sure it's the pump, I hate to make a small but radical modification to my wiring only to find that I've not fixed my problem. Now I've seen on eBay a couple of washer fluid reservoirs with (per the description) working pumps attached, but I hate to go through the trouble of obtaining a spare reservoir and pump, only to find the pump is potentially as weak as my current one.
What I'd really LOVE to find is a "new old stock" pump that has the correct connections but is otherwise unused. Anybody know a source for something like that?
Thoughts? Is there something else I should check before going ahead and splicing in the new pump? Thanks for any help.
C. Gadda is offline   Reply With Quote
Old 02-16-2021, 02:52 PM   #2
billr
Default Re: Minor Washer pump dilemma
Connect the "plumbing" to the new one you have and power it direct from the battery to see if it pumps OK; then mod the wiring. The polarity of the pump probably matters, so be sure to get that right or it may not pump at all.
Old 02-16-2021, 02:57 PM   #3
Waiex191
Waiex191's Avatar
Did you blow out the spray head? That is the part most likely to be plugged.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-16-2021, 03:20 PM   #4
C. Gadda
I believe they did the nozzles as well. I have ordered a pair of new OEM ones just on speculation (after all, it is an almost 26 year old car...)
Old 02-16-2021, 06:34 PM   #5
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
I would check the wiring going to the pump to air sure itís getting a full 12-14 volts. Too low of voltage and the pump wonít work at full power. Mine last summer developed a bad ground and wouldnít turn on at all.
If you do need a new one, you could try grabbing one from the junkyard for the original connection. They arenít a very common part to fail
97 SL2, auto, 123K miles
Old 02-16-2021, 09:50 PM   #6
C. Gadda
Thanks for the tip. Since my car was at my mechanic for a smog check, I had them take a look at the voltage - turns out it was fine so it is more likely my pump that's worn out.
Old 02-19-2021, 12:59 AM   #7
Greg1
Greg1's Avatar
1997 SW2
I worked on an intermittent washer spray problem recently and when I went into it to replace the pump I found slime in the bottom of the reservoir which was clogging the pickup. After cleaning it out the sprayer worked like new with the old pump reinstalled.
97 SW2 5-Sp 273k -mine
Old 02-20-2021, 09:50 AM   #8
I've seen blue slime from the food coloring or whatever they use in windshield wiper fluid.
what I've been doing is letting the fluid run low towards end of winder, then using distilled water throughout spring and summer. Might add a drop of dish soap or an oz of white vinegar if I remember
Old 02-20-2021, 10:20 AM   #9
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Remove tank, put in dishwasher. (after saving the fluid inside)
Turn OFF heated wash, heated rinse, and heated dry, and do not let the spouse catch you.
Reinstall...
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 02-22-2021, 12:08 AM   #10
StarLady
StarLady is just really niceStarLady is just really niceStarLady is just really niceStarLady is just really nice
StarLady's Avatar
1992 SC
I'm glad I came across this thread. I too have been having intermittent issues with the windshield cleaning fluid sprayer. I don't need to use it very often, so I haven't bothered to find a solution. I didn't know about the slime that may accumulate at the bottom of the tank... and I didn't know that it would be okay to use plain water. I'll definitely keep these things in mind for when/if I decide to do something about it.
Wait... wouldn't vinegar mess up the paint?
1992 SC - TwinCam (Automagic)
Bought it brand new, and still loving it today.
StarLady is offline   Reply With Quote
Old 02-22-2021, 03:59 PM   #11
It's theoretically possible, as it is about 5% acid, but we are talking about an oz of vinegar in a half gallon of distilled water (gallon, for 3rd gens with the larger washer reservoir). If you wash while not moving, most of the liquid will drain down the windshield, and if you wash when moving, only a little will run along the roof and door pillars and will quickly evaporate. Probably won't even strip any wax.
Here's an actual test of vinegar held onto car paint for 2 hours, no damage to paint was visible
https://chemistry.stackexchange.com/...harm-car-paint
Old 02-23-2021, 07:11 AM   #12
I've made my own washer fluid using a recipe found here. They use way more vinegar in the summer mix than I do. I tested my winter mix by leaving the jug outside in -10F ambient temps. The blue (or other) is just add coloring.
https://www.yourmechanic.com/article...samson-dikeman
Windshield washer fluid is a brightly colored liquid made of methanol, a poisonous alcohol. Sometimes, small amounts of other toxic alcohols, such as ethylene glycol, are added to the mixture.
https://medlineplus.gov/ency/article/002803.htm
And a MSDS I found for one brand, shows 1/2 methyl alcohol and 2/3 water
https://www.corcraft.org/wcsstore/Ad...20to%20Use.pdf
Old 02-23-2021, 11:29 PM   #13
StarLady
StarLady's Avatar
1992 SC
Thank you, alordofchaos, for all that good info. I had never bothered to find out what washer fluid really was. I could be the only person that didn't know about this, but maybe it will help others.
And I agree, a very diluted water/vinegar solution will not be a problem. The instructions on the site you linked use a 25% solution, but 20% or even less would work too.
Old 02-25-2021, 02:56 PM   #14
Yeah, I'm only using an ounce or two of vinegar in a half gallon of water, lol.
Also just noticed the typo
should be 1/3 methyl alcohol
first gen washer pump blacknbluevue Vue Tech 3 02-15-2016 01:59 PM
Windshield Washer pump where to get? ZepSL2 S-Series General 6 01-30-2015 08:03 AM
Washer pump '08 Astra XR canadian.av8r Astra Tech 5 11-25-2014 01:05 PM
03 Vue front washer pump bo03vue Vue General 7 05-20-2012 11:06 AM
'09 XR washer pump road_rascal Aura General 16 01-05-2011 05:06 PM
