Closed Thread
Old 01-24-2002, 06:30 PM   #1
2000sl2blue
2000sl2blue is on a distinguished road
Question Need tips on a 2000 SL2 Front Brake job
I am getting ready to replace the pads and rotors on my 2000 SL2. They already have 60000 miles on them and are really worn down. Are there any special tools i will need? I am just not sure how to remove the rotors? Also, can i just use a C clamp to compress the caliper piston?? thanks in advance!
Nick
Also has anyone used autozone brake pads or rotors or KVR carbon Fibre brake pads?? thanks!
2000sl2blue is offline
Old 01-24-2002, 10:11 PM   #2
ssicarman
ssicarman's Avatar
Default
14mm takes the calipers off of the mounts. 18mm takes the caliper mount bolts off, reinstall with loctite blue. The caliper piston can be pushed back in with a c-clamp or a pair of large water pump pliers. Clean the rust from the mounts where the pads go on and use a special brake lube to lubricate the caliper slide pins. Don't use grease, the rubber parts don't like it.
ssicarman is offline
Old 01-24-2002, 11:24 PM   #3
2000sl2blue
Default
Thank you!
Old 01-25-2002, 11:02 AM   #4
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Need tips on a 2000 SL2 Front Brake job
Nick
it's fairly easy with a chilton's manual in hand. no special tools. a c-clamp works on the front pistons. use silcone to lube the guide pin and lock pin and the clips after you clean everything with brake cleaner.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-25-2002, 12:57 PM   #5
Spanky
Spanky is on a distinguished road
Spanky's Avatar
Default
I've used Autozone pads and rotors on most of my cars, and I've always liked them. I like the carbon metallic pads, but they are meant for aggressive driving. If you rarely get on the brakes hard, or you 'ride' the brakes with light pressure, the carbon metallics will squeal.
Spanky is offline
Closed Thread
tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire grinthenbearit S-Series Tech 9 10-07-2008 06:22 AM
96 SL2 ABS front brake job dbaier S-Series Tech 2 09-19-2008 11:43 PM
Front Wheel Bearing & Hub job Tips & Part #'s. CND_SC1 S-Series Tech 5 05-13-2008 11:37 AM
Brake Job Tips: Hose Clamp; ABS Sensors. seadog95 How-To Library 3 02-15-2006 05:28 PM
1st Brake Job on 2000 SL2 persephinne S-Series Tech 5 02-14-2006 09:53 AM
