Old 09-20-2022, 11:08 AM   #1
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
Default Spark plug wire keepers
My 2002 SC2s has the retainers that lock the plug wires to the coils and engine.l
I take them off and leave them off. ( replace coil bolt wirh shorter one)
Has anyone ever actually had a plug wire fall off?
I haven't.
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-20-2022, 01:16 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Spark plug wire keepers
Nope, not in 56 years of car ownership.
Old 09-20-2022, 04:12 PM   #3
onlinebiker
I think some engineer was worried about his job - so he created a problem - and surprise, surprise - he also had the remedy.........
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-20-2022, 04:18 PM   #4
onlinebiker
Come to think of it - I DID have a plug wire fall off once.
On a R/C airplane I built. A 42 inch wingspan biplane with a Quadra 42 cc gas engine (basically a chainsaw engine)
It was literally 10 times the needed power. ( or more).
Somewhere I have a VHS tape showing me doing a deadcstick landing with this monstrosity. It had the glide ratio of a brick.
The plug wire fell off due to the extreme vibration...
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-22-2022, 04:10 PM   #5
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
I always thought they were just to make things neater under the hood. I'm all for making things neater if I can.
cujoe_da_man is offline   Reply With Quote
Old 09-23-2022, 09:24 AM   #6
onlinebiker
I think perhaps we are talking different bits.....
The locks are at wire' s ends - and do nothing to neaten things up. They affix the spark plug end to the valve cover bolts and the coil end to the coil mount bolts...
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-23-2022, 10:34 PM   #7
cujoe_da_man
Ooooh, I get it now... I don't think I've ever seen that before. I've only ever seen the plastic bit that holds the wires down on the coils themselves, which is odd because not every car/manufacturer does that.
Old 09-24-2022, 08:22 AM   #8
#4 on every '98-'04 Subaru I've owned has fallen off the coil. No other cylinder, just #4. New, old, good-used...every stupid one.
I never had that issue with the S-Series and they didn't add the retainer until '00 while I only drove '93-'97's.
Spark Plug Wire Help awhat? S-Series Tech 6 04-24-2007 10:20 PM
Spark Plug Wire #1... PitchBlackSC2 S-Series Tech 1 11-08-2005 10:48 AM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 02:09 PM
Spark plug wire set coliphage S-Series Tech 14 07-08-2004 09:22 PM
Spark Plug Wire Help... Rob1998SL2 Mods and Performance 8 10-16-2003 03:09 PM
