Old 09-17-2022, 02:13 PM   #1
dakota1820
dakota1820 will become famous soon enoughdakota1820 will become famous soon enough
2001 SC1
Default How is this subframe rust
I would imagine at the age these cars are some rust is a given. At what point do you replace a subframe? Or at least say that's compromised. Is this one there yet or is it still ok?
dakota1820 is offline   Reply With Quote
Old 09-17-2022, 05:19 PM   #2
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
Default Re: How is this subframe rust
Looks decent, the bubbling would not concern me until it is fully through or can be poked through with a screwdriver.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 Sw2 5spd: Daily, Stock: 105,000
Old 09-17-2022, 05:43 PM   #3
dakota1820
2001 SC1
Ok good to know. Wasn't sure if the metal separation was a concern or not between the layers of the subframe
Old 09-17-2022, 11:10 PM   #4
Duner
Duner is on a distinguished road
1998 SL1
Mine is worse than yours. Here is what I did to mine. Post # 6964
http://www.saturnfans.com/forums/sho...54031&page=349
I fog mine with oil come fall before the salt season.
Duner is offline   Reply With Quote
Old 09-18-2022, 07:56 AM   #5
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
personally i would call that pretty severe and i'd suggest keeping an eye out for a clean subframe at a junkyard while we can still find them. it's cheap enough to buy one and a relatively trivial swap overall (you can support the powertrain with a ratchet strap and a good external hoist point) and a good time to replace worn lcas while you're at it.
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
Old 09-22-2022, 04:34 PM   #6
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
Just curious about what your method is for using oil under the car. Do you sand/wire wheel the rust already there? Do you prep with anything before applying? What do you use to apply the oil with? How long does it tend to last (I know it's not permanent)?
I've been looking at different things myself and want to know more about what you do. So far my trailing arms are solid, but seeing stories here and having owned a '95 Grand Prix with failed trailing arms has me looking at preventative measures.
cujoe_da_man is offline   Reply With Quote
Old 09-22-2022, 09:12 PM   #7
Duner
1998 SL1
I wash the mud off and blow loose rust off. I use a 3M Body Schutz gun # 8997 that I purchased 40+ years ago. They are expensive now but there must be similar at Harbor Freight or some place for less money. I spray them every fall if car gets used in winter. Inside the doors I use Fluid Film applied thru rain drains as there is less mess. I added a piece of rubber hose to Body Schutz gun for ease of use. Don't add long piece of hose as it is siphon feed, it will build pressure inside and it will cover you in oil via the vent on the gun. I did not get my Saturn till it had rust issues and was 18 years old.
Old 09-23-2022, 10:37 PM   #8
cujoe_da_man
I'll look into doing that, I need to swap to my winter tires at some point and redo some work on a failed heat shield above the muffler. I've been saving old oil so I could apply it to the deck of a big trailer we got and have quite a bit left over.
Old 09-24-2022, 05:36 PM   #9
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
Could you clean most of the rust off and use one of those rust converter products and then paint it?
It's GOOD to have a spare!
termite is offline   Reply With Quote
Old 09-25-2022, 09:49 AM   #10
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
I second oiling it.... Park on a dirt driveway on a hot day and squirt it on... Get lots on the top of the subframe - it will make it' s way inside the frame just like it did on the passenger' s side from changing the filter. You' ll never see a subframe rusted out on the passenger' s side...
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-25-2022, 08:59 PM   #11
cujoe_da_man
The thought has crossed my mind, but at this point in the year, I'm running out of time for projects. I also didn't get the vacation time I thought I would when I got full time (have to be in it for a year), so this will be an ok trial run.
If I do something long term, I'll sand down what I can and get some POR15. My dad keeps saying we need to do that for some of our equipment and I remember my grandpa talking about a car he had in the 60's that he poured it down the inside of the doors (the type of car escapes me, but they were known to rust out the doors first). He said the rest of the car got rust, but the doors always looked new. Someone else here mentioned using it on the oil pan since mine was looking a bit crusty in the front. They said just slather it on and call it good.
I did use the oil with a small amount of diesel to thin out the mix to treat a really, really aging deck on a trailer my dad bought. They were rough sawn 2x6's (true sizes), but the guy that had the trailer never did anything to the deck. I slopped it on there three times with a roller and it makes the boards look like railroad ties.
Old 10-02-2022, 12:26 AM   #12
Bob243
Bob243 is on a distinguished road
Bob243's Avatar
1991 SL1
My 95 was somewhat bulged out less than yours, I brushed a little bit of this on the area last year. ( I just finished doing this on the whole frame of my GMC as well ) I just applied it with a throw away chip brush from my shop
https://www.eastwood.com/eastwood-ru...-platinum.html
Bob243 is offline   Reply With Quote
Subframe Rust adam22 Vue General 24 10-13-2020 04:59 PM
Subframe rust on a 2000 SL1 ZadZ S-Series Tech 6 05-09-2019 10:29 AM
03 vue subframe rust? Cavell Vue General 1 12-17-2017 11:15 AM
Subframe rust and safety satmark S-Series Tech 6 05-05-2015 08:06 PM
Subframe rust has begun jchu210 S-Series General 8 05-17-2014 11:11 PM
