Old 09-11-2022, 06:34 PM   #1
Vellyn
Vellyn is on a distinguished road
1997 SW2
Wrench Advice! 1997 Saturn SW2
The car just recently got a new battery (for the 4th time). Now has a new alternator (2nd one so far), a new starter, a new master cylinder, and new bolts for connecting the cables into the battery. As well as a new air filter.
Just recently, for no obvious reason, the lights started going dim inside the car, then flickering, then the gauges started going haywire, the battery light was constantly flickering. The rpms went up but the car was barely getting up and going (basically like it was being pulled backwards while you are trying to go forward) shifting hard at times.
The alternator is brand new, just replaced. The battery is brand new as well. We have new spark plugs and air filter... all the fluids are at the point they need to be...
What is going on? We really don't want to sell it but we are stumped as its electrical or not? Bad ground? A short? Fuse? Relay? Sensor?
Please Help 😅😓
Vellyn is offline   Reply With Quote
Old 09-11-2022, 06:52 PM   #2
N147JK
N147JK is a jewel in the roughN147JK is a jewel in the roughN147JK is a jewel in the rough
Default Re: Advice! 1997 Saturn SW2
Are you saying this only started happening after the latest electrical work? If that's the case, there must have been a mistake made installing the new parts, ie, either wrong part or maybe something is miswired. I'd back those parts out one at a time and see if it uncovers the problem.
N147JK is offline   Reply With Quote
Old 09-11-2022, 07:15 PM   #3
The automatic is very sensitive to voltage fluctuations, if the electrical is going crazy then the auto will too. Sounds like either the alternator failed or a battery cable came loose.
Old 09-11-2022, 07:58 PM   #4
Vellyn
1997 SW2
No, it happened before the new parts were put on. The battery was dying/not charging so we thought the alternator must have gone out again. We replaced it and the battery. Everything was fine and tested to be sure they worked properly. After we put them on the problems stopped for like 10 minutes and then they came back. Low rpms and the car barely going. The lights flickering and going dim, the battery light flickering.
Old 09-11-2022, 08:00 PM   #5
Vellyn
1997 SW2
Old 09-11-2022, 08:36 PM   #6
SRGW
SRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to behold
SRGW's Avatar
1997 SL1
Post Re: Advice! 1997 Saturn SW2
Could this be a bad fusible link wire from starter to alternator??
1995 SL1 236,300 2005>2018
1997 SL1 100,100 2014>????
CHECK YOUR OIL!!
Old 09-14-2022, 09:13 PM   #7
hholbein
hholbein is just really nicehholbein is just really nicehholbein is just really nicehholbein is just really nice
1997 SW2
If you have an electrical fault in your wiring or a bad relay, you will need to do some sleuthing with a multi-meter. Here's a link to Eric O's South Main Auto Channel. Eric does a good job showing how to approach these faults systematically before spending tons of $ with the parts canon. Use Youtube search on his page for "drain" and a bunch of diagnostic videos pop up.
Fortunately, the wiring on these cars is simpler than newer cars, so it should be easier for you. Let us know how you get on?
https://www.youtube.com/c/SouthMainA...ch?query=drain
1997 Radio/CD/Equalizer swap advice dummo S-Series General 4 12-18-2020 12:24 PM
1997 SC2 DOHC Cylinder 3 Dead - Advice Please? rlacapra1 S-Series Tech 4 02-20-2013 08:27 PM
Purchased 1997 SL1 - Could use some freindly advice Chris0381 S-Series General 9 05-28-2005 02:43 PM
Need advice on 1997 SC2 bromeoSC2 S-Series General 2 05-25-2005 03:31 PM
1997 SC2 timing chain advice/comments chicagomike S-Series Tech 5 05-13-2005 09:22 AM
