#1 |
![]() Join Date: Dec 2009
Looking for a good motor twin cam motor hiding in storage. Have kept up with reg maint and hate to junk it after 292k.
#2 |
![]() Join Date: Oct 2022
What year?
#3 |
Any motor 95-02 would work. The fuel rail & injectors have to be carried over and other minor swaps perhaps like the knock sensor. My SL2 is a 98 automatic.
#4 |
The heads are not the same after 2000. The exhaust and intake manifolds are different.
Where are you located? |
#5 |
The fuel rail also changes in '98 from the return style in '97 with a $5 fuel filter option to returnless with a $50+ filter in '98. Not sure if the rails will swap '96-'99, but whatever years I tried had the mounting boss's in different locations on the intake (only had '93-97's).
Just something to check while the engines are out of the car, easier to swap the IM while it's out if it's required (and could probably have it walnut blasted to clean the carbon/oil out). |
#6 |
In mid 1998 the production was changed. Head, manifolds are different.
#7 |
Appreciate the responses! The heads are different in later years but it does not matter, what is important is to use the original fuel rail/injectors. The exhaust manifold on my 98 will bolt on to any of the blocks. I did this with my 97 SOHC and swapped in a 02 SOHC.
#8 |
Like to add I'm in Ohio and travel to Florida for possible pick up.
#9 | |
![]() Quote:
#10 |
The plastic and aluminum intake manifolds can be interchanged??
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
My '99 has an aluminum intake.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() Quote:
https://www.wholesalegmpartsonline.c.../21006844.html https://www.wholesalegmpartsonline.c.../21008443.html
1999 SL2 MT (311,300 km @ 01/2023) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#13 |
Bookmarks |
wiper motor compatibility? 2002 sl2 motor in 97 sl2? | vikasevan | S-Series Tech | 2 | 04-04-2015 03:06 AM |
1998 sl2 1.9 motor slight vibration at idle only 32000 on motor any ideas other than | Robertssaturn | L-Series Tech | 1 | 05-31-2010 08:15 PM |
Compression test Warm motor vs cold motor | Frankd1 | S-Series Tech | 2 | 10-14-2008 04:47 PM |
saturn motor sports monster motor block? | wastedatmu | S-Series Mods | 7 | 02-06-2007 11:18 AM |
HVAC Blower Motor Dying...can one fix motor? | flyhop | S-Series Tech | 2 | 09-28-2006 10:08 PM |
