Old 01-14-2023, 08:54 PM   #1
MrAndersonGCC
MrAndersonGCC is on a distinguished road
Default A whine and a clunk
Calling all Sherlocks.
2002 SL2, manual.
The Clunk
Occurs under 10 mph when turning, but only occasionally. Cannot replicate on demand. Control arms, tie rods ends, struts, and cv axles have all been recently replaced. I can’t recall if I replaced the strut mounts or not, but I must emphasize that the clunking does not occur when normal driving over bumps. Only thing I can think of is perhaps the sway bar itself. I replaced the bushings not long ago. But my understanding is our sway bars contain a “mirror” bar inside the sway bar that can come loose and clunk against the inner wall of the “big” bar, if that makes sense.
The Whine
Not a squeal, not super high pitched. Replaced the ps pump, water pump, belt tensioner, and belt itself all in the last week.
It gets slightly better as the car gets warmer, which made me sure it was the belt, but it obviously wasn’t. I tried listening using the old hose trick but that really didn’t narrow it down. There’s only the alternator and idler pulley left (I have an ac compressor but it makes the noise while it’s off). Before I go changing those, is there anything not belt-driven around the passenger side of the engine that could make such a noise? It does increase with rpm‘s, and in neutral sitting still.
Thanks
- Anderson
MrAndersonGCC is offline   Reply With Quote
Old 01-14-2023, 09:11 PM   #2
billr
Default Re: A whine and a clunk
Can you make the whine go away by removing the serp belt?
I don't think the sway-bar has an "inner" bar; it is tubular except at very ends where the threaded studs are pressed/welded in.
PS: The A/C pulley is still turning, even if compressor is not. Could still be a bearing in there squealing.
Old 01-14-2023, 09:16 PM   #3
MrAndersonGCC
Ah, kicking myself for not running it without the belt when I changed it earlier. I’ll try that next, thanks.
Old 01-14-2023, 11:47 PM   #4
93twincam
93twincam is on a distinguished road
2002 SL1
When you replaced the PS pump, did you ensure you bled all the air out of the system? PS pumps will whine at various pitches/volume depending on how much air is in the system.
2002 SL1 5 speed - 165,xxx - Current daily
1993 SC2 5 speed - 200k - Unfortunately sold
2002 Silverado Z71 - 185,xxx
2007 Impala 3.5L - 365,xxx - Still running good, daily backup
93twincam is offline   Reply With Quote
Old 01-15-2023, 12:28 AM   #5
MrAndersonGCC
I did the typical lock-to-lock method and added fluid as the level dropped. I’ve leaned my head towards the ps pump and the noise actually decreases back there.
Old 01-15-2023, 11:26 PM   #6
MrAndersonGCC
Well I ran the car with the belt off and it was quiet. Almost 100% certain it’s the idler pulley.
The clunk is driving me nuts though. Usually happens when going in reverse, turning sharply, and going over a bump. Is there anything I’m missing that could cause this?
Old 01-15-2023, 11:50 PM   #7
MrAndersonGCC
I’ll add that if I lock the wheel either left or right and continuously move forwards or backwards, there isn’t a clunk. It’s pretty much when there is a combination of turning AND a bump, and at low speed. I can confirm when I did the struts I didn’t do the strut mounts. Could those be the cause of this? I would think bad mounts would make noise all the time when going over bumps, but my this noise is so specific.
Old 01-16-2023, 01:01 AM   #8
billr
What ever the strut spring(s) "swivel" on, lube it. The end of the spring coil may be hopping in/out of its seat in the swivel if the swivel is binding.
Old 01-16-2023, 09:59 AM   #9
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Maybe a worn powertrain mount has some play.
The ABS makes an odd dragging sound followed by a small clunk, only
when first moving off at speed less than 10 mph.... sounds like a ghost in a horror film sliding along a wooden sound board before engaging a huge 'skeleton' key.
Old 01-16-2023, 10:43 AM   #10
MrAndersonGCC
I like your description but it doesn’t sound like ABS. I replaced all engine mounts in the last few months. Didn’t do the transmission mount but this would be a very bizarre symptom of it was the transmission mount.
Old 01-16-2023, 10:45 AM   #11
MrAndersonGCC
That’s a good idea. I may replace the strut mounts while I’m at it - can you suggest any good brands? I was going to get kyb but I’ve read a lot of bad things.
Old 01-16-2023, 02:23 PM   #12
billr
Sorry, no suggestion on brand. My "94/95s only have 250+K miles on them; never had to fuss with struts.
Old 01-16-2023, 03:50 PM   #13
93twincam
2002 SL1
250k and never has struts???? Maybe you know something I don't know, but I've never heard of a strut lasting that long...
Old 01-16-2023, 11:10 PM   #14
MrAndersonGCC
Recorded a short video of the clunk: https://youtube.com/shorts/DCotbPqjUfk?feature=share
Old 01-17-2023, 12:42 PM   #15
trottida
trottida's Avatar
That sounds like your strut mount is binding. There is a bearing in the strut mount and when if fails the spring resists until there is enough force and creates a pop noise like you're hearing. Replace the strut mounts or if the strut has some age just go ahead and replace the strut assembly. It'll save you some time and effort.
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 01-17-2023, 01:48 PM   #16
MrAndersonGCC
Ok thanks. Are you able to suggest decent strut mount brands? There’s not a lot of options and kyb mounts have a bad reputation despite making great struts.
Old 01-17-2023, 04:37 PM   #17
trottida
trottida's Avatar
I've always replaced the entire assembly rather than doing piecework. Last time I bought them I went with Monroe QuickStruts and I have no complaints. I couldn't speak to just replacing the strut mounts. Someone else should chime in.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-17-2023, 05:25 PM   #18
MrAndersonGCC
I recently replaced my struts with kyb but left the mounts alone.
After doing some research I opted to order two new acdelco mounts.
Old 01-21-2023, 12:01 AM   #19
MrAndersonGCC
Ok the whine has been taken care of, was the idler pulley. Interesting thread on that one, billr was a great help.
Just replaced both strut mounts and I believe I heard a clunk on the first drive, though it was a short one.
What in the world could I be missing? The only suspension part that hasn’t been changed in the last couple thousand miles is the sway bar itself. This is nuts. And it is 100% coming from the front.
Old 01-21-2023, 01:45 PM   #20
billr
I finally listened to the video in reply #14. Is that whine from the idler, and gone now? A new video may help. I would do it with the engine off, even though whine is gone. Also, try it with one wheel, and then the other, and then both off the ground. See if there are any changes.
Do you have a helper to turn the steering wheel, so you can watch/video everywhere under there while the is happening? Let me rephrase that... you must have a helper to do so, or this may never be solved without a whole lot of parts-swapping!
We may even have to go to the "grease sandwich" to track this down.
Whine ocatrina L-Series Tech 2 08-05-2008 03:22 PM
Whine DHOOP S-Series Tech 6 04-17-2007 05:42 PM
whine justin_zink S-Series General 4 11-29-2005 12:31 PM
vti whine fix walt Vue General 1 10-18-2003 06:43 PM
My car has a odd whine at low rpm's Mongoose159 Mods and Performance 16 12-10-2002 01:59 AM
