Old 04-23-2007, 12:18 PM   #1
karinhesed86
karinhesed86 is on a distinguished road
karinhesed86's Avatar
Default Dome Light
Mine randomly fell out while I was driving yesterday and is now dangling by its wires--I tried putting it back in place, but it just doesn't stay--any suggestions as to how to get it back in place? I don't have my Haynes manual with me, and I doubt that that's in there....thanks...
2002 SL2 Automaic... going strong at 89,000 miles.
karinhesed86 is offline   Reply With Quote
Old 04-23-2007, 01:14 PM   #2
zukgod1
zukgod1 is on a distinguished road
zukgod1's Avatar
Default Re: Dome Light
Sunroof or no? I only ask as I dont want you to drill into the glass.
I had that problem and dang near went and bought a new one.
instead I just used a small screw about 1/4 inch long and drilled a pilot hole for it to get started in and screwed it up there.
There is a small flat area next to the bulb, I just removed the bulb, check to make sure the wires were not in the way.
Screwed it in and hasn't fell off yet.
dan
98 SL2. A work in progress!
zukgod1 is offline   Reply With Quote
Old 04-23-2007, 01:34 PM   #3
karinhesed86
dan
nope no sunroof...where would i put the screw?
Old 04-23-2007, 01:39 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
are the clips broken off? Should be two clips one one end, one on the other (the 2 are the ones that often break off...)
Old 04-23-2007, 04:09 PM   #5
Exto
Exto is on a distinguished road
Exto's Avatar
If you screw it into the roof with a short screw, you can go anywhere inside of the lens as long as you don't hit the metal conductors for the dome light. Just to let you know, a new dome light from saturn will run you about $23. Like PurdueGuy said, the ususal problem is that the clips on the switch end of the light get brittle and break.
I agree with Henry Ford on automotive color options. I'll paint it any color you like, as long as it's black.
Exto is offline   Reply With Quote
Old 04-23-2007, 08:49 PM   #6
tarsun
tarsun is on a distinguished road
i used velcro. the problem is that the light clippy thinggy becomes very brittle... every saturn at the junkyard has a broken dome light thanks to yours truly... buy new or use velcro.
tarsun is offline   Reply With Quote
Old 04-23-2007, 08:59 PM   #7
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
"O".......so your the one.....................
Old 04-24-2007, 02:43 AM   #8
karinhesed86
Heh...there were two, but I lost one of the pair of two... I have to find it sometime tomrrow...this poor college student does not have $23 to spare for a new dome light...damn thing...a dead moth fell out of it too....
Old 04-24-2007, 03:12 AM   #9
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Ya I busted my tabs long ago. Double sided foam tape holds it now.
Are Saturns bug magnets? My old SL1 would always get bees in the back window, where the glass meets the shelf. My 97 Sc2 does the same thing. I still have a dead bee back there because I keep forgetting about it.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 04-24-2007, 07:57 AM   #10
Jim Dunlop
Jim Dunlop is on a distinguished road
Jim Dunlop's Avatar
2002 SL
1998 SL
I had an insect or two in mine too. Yes, the tabs broke off. I had removed it to install an LED "bulb" from autolumination.com, but it's less bright than the stock incandescent bulb. Also, even after the LED fades out when I shut the door, there appears to be a small amount of current continuing through it...that makes me nervous.
Thanks for the velcro comments. I tried to re-create tabs by epoxy-ing bent paper clips in place of the original tabs, but one fell off and my dome light is lop-sided now.
2002 SL 1.9L SOHC 5-spd mods:
-Custom HAI
-K&N Airbox Filter
-Custom Air Dam
-PCV Catch Can
-Drilled & slotted rotors
-14x6 König Incident's, Yoko AVID's
-Grille Block (aluminum)
SCS! DD.
Jim Dunlop is offline   Reply With Quote
dome light bone86daddy S-Series General 12 10-12-2008 09:35 PM
Dome Light spachek Miscellaneous Tech 1 06-07-2004 08:15 AM
Dome Light Adman Classifieds 1 04-21-2002 08:51 PM
Help cant see...need dome light Sabrina General Saturn Discussion 8 01-21-2002 04:52 PM
Dome light dbaker Miscellaneous Tech 3 04-25-2000 07:27 PM
