Old 03-03-2002, 07:42 PM   #1
billchez
billchez is on a distinguished road
Question how to remove the manual window handle??
I`m been trying to remove the door panels I`ve got everything but the roll up handles??? can anyone help
billchez is offline
Old 03-03-2002, 08:00 PM   #2
Default
The door handles are held in by a spring clip. It is best removed by using a door handle clip removing tool. If not this then a bunch of poking and proding in behind/under the handle with a small screw driver or hooked pick should allow you to get the clip out and the handle off.
ssicarman is offline
Old 03-03-2002, 10:17 PM   #3
sattech
sattech is on a distinguished road
Default
The tool is in the $5-$10 range, A universal tool you can buy at almost any patrs store. Even if you only use it once, it's worth it from an aggravation standpoint
sattech is offline
Old 03-08-2002, 06:51 PM   #4
e_sloan
e_sloan is on a distinguished road
e_sloan's Avatar
Default
A free "tool" to remove the door handles is a rag. Just slide it between the handle and the door and keep on running it back and forth at a bunch of angles. Eventually it will catch the pin, sometime sooner rather than later, but it does work for free.
e_sloan is offline
Old 03-08-2002, 11:16 PM   #5
billchez
Happy thanks
Thanks for all the info . The rag worked great and the cost was just my speed. thanks again. My wife can enjoy the new speakers now.
billchez is offline
How to remove grab handle? The Guardian S-Series Tech 7 04-22-2009 04:59 PM
97 SC2 Door Handle/Window help techieguy S-Series Tech 5 11-09-2007 09:28 PM
Manual windows, handle is stripped DJboozeAlot S-Series Tech 5 08-16-2007 03:37 PM
how to remove liftgate handle on 2006? steinfire Vue General 19 01-17-2007 01:37 PM
Window handle hell Miss_SC2 S-Series Tech 10 11-29-2004 03:58 AM
