Old 12-08-2005, 02:59 AM   #1
iheartmysaturn
iheartmysaturn is on a distinguished road
iheartmysaturn's Avatar
1993 SL2
Default did it overheat
a few weeks ago i was cruisin down the freeway and the battery light came on. i was kind of happy because i had had some auto tranny problems. but then i finnaly noticed the temp gauge climbing but it was already passing 3/4 mark i got it in neutral and off just before it hit red. i was wondering if this was going to start to cause problems when i pull her back out in the spring. and by the way the belt tensioner siezed up and shot the pully off.
~1993 Saturn SL2m
iheartmysaturn is offline   Reply With Quote
Old 12-08-2005, 03:02 AM   #2
scort_beater
scort_beater is on a distinguished road
Default Re: did it overheat
sounds like you just need to put on a new tensioner and belts that might just be the problem i am not sure but the water pump may run off teh same belt as the alternator might just be that
scort_beater is offline   Reply With Quote
Old 12-08-2005, 03:08 AM   #3
iheartmysaturn
1993 SL2
that was the problem it ran fine for another week until i put it away but i want to know if problems will show their ugly faces later. the oil and coolant are still clean so i figured it would be ok but now im not so sure
~1993 Saturn SL2m
Old 12-08-2005, 03:25 AM   #4
scort_beater
if you shut it off b4 anything major happened which it sounds like you did i'd have to say you shouldn't have anything to worry about
Old 12-08-2005, 04:53 AM   #5
willfxp
willfxp is on a distinguished road
1997 SW2
Why were you happy that the battery light came on and/or you had auto transmission problems? Usually that light comes on when your alternator is dead. Have you been driving the car? Might want to get your electrical system checked (usually free).
1997 Saturn SW2
willfxp is offline   Reply With Quote
Old 12-08-2005, 08:34 AM   #6
BarnOwl
BarnOwl's Avatar
He was happy because the transmission is electronically controlled and can be affected by a weak charging system. He'd rather have an alternator problem than a transmission problem. So would I for that matter.
Old 12-08-2005, 10:53 PM   #7
iheartmysaturn
1993 SL2
thanks for clearing that up
~1993 Saturn SL2m
Overheat troubleshooting senorpineapple Ion General 2 10-11-2009 08:23 AM
Strange overheat problem? myrmidon S-Series Tech 8 07-07-2009 08:13 AM
Strange Overheat acworthpatrick S-Series Tech 17 01-22-2009 12:36 PM
97 sl2 overheat davidfleeson L-Series Tech 1 09-29-2007 10:31 PM
Overheat with needle at 1/2 to 3/4? Quadragin S-Series Tech 5 12-16-2004 06:44 PM
