#1 |
![]() Join Date: Jun 2004
I am getting a leak from the coolant resevoir bottle. My check coolant light came on and I looked under the hood and it appears that all the main hoses (upper and lower rad hoses) are dry. Under the coolant bottle is a wet area. I haven't taken it apart yet, but I suspect the bottle is the problem or the coolant level sensor is leaking.
Has anyone had this happen before? Thanks |
#2 |
![]() Join Date: Aug 2004
If you have an s-car, I have seen a few bottles that were the culprit. Have not seen on any other models.
#3 |
#4 | |
![]() Quote:
The sensor seal at the bottom of the tank is leaking and causing the coolant light to go off. As tank is over 10 years old, I replaced it with a new one. |
#5 |
It was the o-ring on the coolant level sensor that was bad. When I pulled the connector off, the o-ring literally fell apart in my hands. Got a new bottle off a 2000 with only 55K on it for $5. Problem SOLVED!
#6 |
Why didn't you just replace the O-ring?
![]() Seems like a lot of hassle to go to a junkyard and source a $5 part, when you can pick up a whole package of O-rings for practically the same price at any auto parts store. (Not talking money here, just time. Simply curious.) |
#7 |
I go there just to see what I can find. Plus this bottle is a lot cleaner
#8 |
I can understand that perspective.
Bookmarks |
Coolant Leak at Resevoir | WagonsForever | S-Series Tech | 4 | 11-29-2007 02:03 PM |
Coolant resevoir leak! | jsdailey | Vue General | 3 | 10-06-2007 10:52 PM |
Coolant leak from mysterious lines | puer liber | S-Series Tech | 7 | 01-28-2007 10:37 PM |
coolant resevoir | WKDave3 | Miscellaneous Tech | 1 | 03-11-2003 09:37 PM |
Mysterious coolant leak | Pete93SL1M | Miscellaneous Tech | 7 | 10-10-2002 01:34 PM |
