Old 12-01-2022, 04:31 PM   #21
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default Re: the old remove manual window crank trick
hi pierrot- good to hear from you. this seemingly simple job was a huge pain. the design of this was unnecessarily complicated. big problem was you could not see the c part of the c lip. it was actually inside the cover over the axle socket. only way to get it out was by feel with a pick longer than the regulator handle( i thought the regulator was the mechanism which raised the window). dont think the lisle tool designed to remove and install these clips would work. you needed to put the pick end inside the socket cup, raise the c part above the cup edge and then pull it out . seems to me that should have been described in the saturn shop manual. let me know what youre doing for fun. regards bob f
rfisher is offline   Reply With Quote
how to remove window crank rgierer S-Series Tech 17 11-19-2015 06:51 PM
Manual window crank going bad again :( awilson506 S-Series Tech 2 11-22-2012 02:39 AM
need tool to remove window crank GRAFIX111 S-Series Tech 13 08-05-2009 03:52 PM
How To Remove Crank For Window samainfirenight S-Series Tech 6 11-25-2007 09:10 PM
how to remove the manual window handle?? billchez Miscellaneous Tech 4 03-08-2002 11:16 PM
