Old 10-26-2013, 11:16 AM   #1
firstar
firstar is on a distinguished road
Default Reverse dog assembly for TAAT sl1/sl2 auto trans
Hi, Does someone carry the new kit or so to cure the reverse clunk?.. It is definitely the dog clutch assem for reverse.... Has the coming out of reverse to drive and park grind..... A kit or so would be great other than GM ... thanks
firstar is offline   Reply With Quote
Old 10-26-2013, 06:41 PM   #2
Default Re: Reverse dog assembly for TAAT sl1/sl2 auto trans
Transmission repair
http://www.saturnfans.com/forums/sho...nput+shaft+nut
http://www.saturnfans.com/forums/sho...d.php?t=112858
http://www.saturnfans.com/forums/sho...d.php?t=164114
http://www.saturnfans.com/forums/sho...d.php?t=164115
Transmission gasket and nuts part numbers
21003202 is the valve body cover gasket. This fits 96-02
21001684 is the end cover gasket. This fits 91-02
21001679 is the output shaft nut. This fits 91-02
21001680 is the input shaft nut. this fits 91-02
Saturn OEM Parts Source
GM Parts Giant- http://www.gmpartsgiant.com/
GM Parts Direct- http://www.gmpartsdirect.com/
Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643
GMparts4U.com- http://gmparts4u.com/
Your local dealers - http://www.partsvoice.com/
http://www.vpartsinc.com/
Parts numbers
http://parts.nalleygmc.com/default.aspx
Valve body rebuilder: http://www.ebay.com/itm/Saturn-Sonna...item2eba58a855
Valve Body remove-replace How-To video
http://www.youtube.com/watch?v=cwV4TPL3TDg
Transmission Shaft Holding Tool
http://www.saturnfans.com/forums/sho...ighlight=shaft
Transmission parts
http://www.wittrans.com/c-785-taat.aspx?pagenum=4
Here are some skinny sockets with OD specs. Need socket end OD of 1.200" (30.48mm) or smaller.
* Snap-On FM23, 3/8" drive 23mm 12-pt std: 29.9mm
* NAPA 23mm 12-pt thin-wall, special order: sorry no part#
* Armstrong 3/8" drive 23mm 12-pt, std #38-123: 30.2mm
* Armstrong 3/8" drive 23mm 12-pt deep, #38-323: 30.2mm
* Armstrong 1/2" drive 23mm 12-pt deep, #39-323: 30.2mm
* NOT Snap-on 1/2" drive 23mm 12-pt #SWM231: 31.2mm
* NOT Armstrong 1/2" drive 23mm std #39-123: 30.9mm
Snap-on FM23 or NAPA is the 23mm thin wall socket winner.
Old 10-30-2013, 09:40 AM   #3
firstar
Thanks !...
2000 SL2 auto TAAT grinding coming out of reverse, mostly cold bear8ruf S-Series Tech 1 08-28-2013 02:12 PM
95 SL2 auto trans reverse delay & slip? detroitdan S-Series General 6 08-16-2009 04:25 AM
Auto Trans rpm fluctuated in reverse sperf S-Series Tech 1 02-02-2008 08:15 AM
replacement auto trans - no forward or reverse meseville S-Series Tech 4 08-16-2007 12:38 PM
93SL1 AUTO TRANS jerks when reverse myton78 L-Series General 1 11-17-2003 08:57 AM
