Old 09-23-2010, 04:39 PM   #1
Dale002
Dale002 is on a distinguished road
Default Oil Pump seals
I'm in the process of changing the timing chain on a 97 sl2 DOHC
And I noticed one o'Ring on the oil pump hole but only on the right side hole ,
looking at the engine from the pass side.
The other hole had nothing.
Is there suppose to be an O'Ring on each oil passage for the pump?
If so where do I get them. it doesn't seem to be included with any gasket kit as per The auto store.
Dale002 is offline   Reply With Quote
Old 09-23-2010, 06:43 PM   #2
Default Re: Oil Pump seals
Yes, is it stuck in the cover? The right/front one is 21006255 and the left rear one is 21006176. They are also in the head gasket kit and complete engine kit if you get it from Saturn. The gasket kits are expensive.
GM Parts Direct lists them at 8.04 for the front one and 2.30 for the rear. Replace both of them. http://www.gmpartsdirect.com/
Get Saturn Parts also lists them. http://www.trademotion.com/splash/in...?siteid=214643
You can forget the parts stores unless you want to buy the full overhaul gasket set from FelPro.
Old 09-24-2010, 11:42 AM   #3
Dale002
I thought theymay come with the oil pump rebuilt kit.
Old 09-24-2010, 12:38 PM   #4
Nope, never.....
(that would make way too much sense)
Old 09-25-2010, 09:14 PM   #5
Dale002
got them order,Thanks
Old 01-02-2017, 06:42 PM   #6
JohnSC
JohnSC is on a distinguished road
Are the oil pump seals the same for SOHC and DOHC engines?
JohnSC is offline   Reply With Quote
Old 01-02-2017, 06:50 PM   #7
Yes, there is a Victor kit of all 3 seals. Rock Auto
95 SL1 - Oil coming out seals CJinMSP S-Series Tech 4 04-14-2007 07:10 PM
SL2 Oil Pump Seals Dale002 S-Series Tech 1 09-02-2006 04:38 PM
SL2 Oil Pump Seals Dale002 L-Series Tech 1 09-02-2006 09:44 AM
Need quick help - replacing power steering pump and water pump on V6…. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
Two oil pump seals things emailer33 S-Series General 3 04-28-2005 04:04 PM
