Old 11-25-2007, 01:14 PM   #1
samainfirenight
samainfirenight is on a distinguished road
Default How To Remove Crank For Window
I am trying to remove the hand crank for the window on a 1998 sc2. I need to get the door panel off and that is the only thing in my way right now. I can't get it off, Im afraid im going to break something....whats the trick?
samainfirenight is offline   Reply With Quote
Old 11-25-2007, 01:46 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: How To Remove Crank For Window
You have to remove the inner and outter door panels. Which one are you having problems with?
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 11-25-2007, 01:56 PM   #3
Old95SL2
Old95SL2 is on a distinguished road
1997 SL1
There should be a C-shaped clip right behind the base of handle that needs to be popped off. I think the open side of it faces the long part of the crank. You kinda have to push against the door panel/pull out on the crank gently to see it there. Any way to get it to pop out of there should work, there is a special tool you may be able to borrow from an auto parts store that makes this much easier to remove. Someone posted a picture a while back on this forum of how to make a tool for this, try searching.
Old95SL2 is offline   Reply With Quote
Old 11-25-2007, 02:05 PM   #4
Old95SL2
1997 SL1
Might take a look here:http://www.saturnfans.com/forums/sho...ht=window+tool
Specifically take a look at the pictures posted by richpin06 in that post.
Old 11-25-2007, 02:40 PM   #5
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
Here is how you use that tool.
http://www.youtube.com/watch?v=NlsHeJ1A-nQ
Old 11-25-2007, 03:22 PM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Not too many window cranks were installed in the outer panels.
And just FYI--that clip that holds the window crank handle on is called a horseshoe clip.
Certified Saturn Technician
Old 11-25-2007, 09:10 PM   #7
So named because it was developed about the same time in history as the horseshoe.
need tool to remove window crank GRAFIX111 S-Series Tech 13 08-05-2009 03:52 PM
window crank removal chaost L-Series General 1 09-21-2008 06:02 PM
Window crank? Phil M S-Series General 4 02-05-2007 07:06 PM
Can I lubricate window crank? Pioneer_Saturn S-Series General 7 02-07-2006 10:22 PM
Impossible to remove crank windows? mrrkrinkle L-Series General 3 01-01-2005 06:10 PM
