![]() ![]() Join Date: Sep 2011
2001 SC1
I would imagine at the age these cars are some rust is a given. At what point do you replace a subframe? Or at least say that's compromised. Is this one there yet or is it still ok?
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
Looks decent, the bubbling would not concern me until it is fully through or can be poked through with a screwdriver.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018) 1994 Sl1 5spd: Inherited, Stock: 495,000 1995 Sl2 5spd: Retired Daily, Not Stock: 198,000 1995 Sw2 5spd: Daily, Stock: 110,000 |
2001 SC1
Ok good to know. Wasn't sure if the metal separation was a concern or not between the layers of the subframe
![]() Join Date: Nov 2017
1998 SL1
Mine is worse than yours. Here is what I did to mine. Post # 6964
http://www.saturnfans.com/forums/sho...54031&page=349 I fog mine with oil come fall before the salt season. |
#5 |
personally i would call that pretty severe and i'd suggest keeping an eye out for a clean subframe at a junkyard while we can still find them. it's cheap enough to buy one and a relatively trivial swap overall (you can support the powertrain with a ratchet strap and a good external hoist point) and a good time to replace worn lcas while you're at it.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#6 | |
![]() ![]() ![]() ![]() Join Date: Sep 2017
2000 SL1
I've been looking at different things myself and want to know more about what you do. So far my trailing arms are solid, but seeing stories here and having owned a '95 Grand Prix with failed trailing arms has me looking at preventative measures. |
#7 |
1998 SL1
I wash the mud off and blow loose rust off. I use a 3M Body Schutz gun # 8997 that I purchased 40+ years ago. They are expensive now but there must be similar at Harbor Freight or some place for less money. I spray them every fall if car gets used in winter. Inside the doors I use Fluid Film applied thru rain drains as there is less mess. I added a piece of rubber hose to Body Schutz gun for ease of use. Don't add long piece of hose as it is siphon feed, it will build pressure inside and it will cover you in oil via the vent on the gun. I did not get my Saturn till it had rust issues and was 18 years old.
#8 |
2000 SL1
I'll look into doing that, I need to swap to my winter tires at some point and redo some work on a failed heat shield above the muffler. I've been saving old oil so I could apply it to the deck of a big trailer we got and have quite a bit left over.
#9 |
Could you clean most of the rust off and use one of those rust converter products and then paint it?
It's GOOD to have a spare! |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015
I second oiling it.... Park on a dirt driveway on a hot day and squirt it on... Get lots on the top of the subframe - it will make it' s way inside the frame just like it did on the passenger' s side from changing the filter. You' ll never see a subframe rusted out on the passenger' s side...
Currently owned 96 SC2 Manual 98 SL2 A(uto) 99 SC2 A 01 SC2 A 01 SC2 M 02 SC2 M (2 cars) 02 SL2 A 02 SL2 M parts 2 94 SC2 parted out 2 96 SC2 98 SC2 - rusty frame minus engine. 98 SL2 |
#11 | |
2000 SL1
If I do something long term, I'll sand down what I can and get some POR15. My dad keeps saying we need to do that for some of our equipment and I remember my grandpa talking about a car he had in the 60's that he poured it down the inside of the doors (the type of car escapes me, but they were known to rust out the doors first). He said the rest of the car got rust, but the doors always looked new. Someone else here mentioned using it on the oil pan since mine was looking a bit crusty in the front. They said just slather it on and call it good. I did use the oil with a small amount of diesel to thin out the mix to treat a really, really aging deck on a trailer my dad bought. They were rough sawn 2x6's (true sizes), but the guy that had the trailer never did anything to the deck. I slopped it on there three times with a roller and it makes the boards look like railroad ties. |
#12 | |
![]() Join Date: Sep 2014
1991 SL1
https://www.eastwood.com/eastwood-ru...-platinum.html |
Subframe Rust | adam22 | Vue General | 24 | 10-13-2020 04:59 PM |
Subframe rust on a 2000 SL1 | ZadZ | S-Series Tech | 6 | 05-09-2019 10:29 AM |
03 vue subframe rust? | Cavell | Vue General | 1 | 12-17-2017 11:15 AM |
Subframe rust and safety | satmark | S-Series Tech | 6 | 05-05-2015 08:06 PM |
Subframe rust has begun | jchu210 | S-Series General | 8 | 05-17-2014 11:11 PM |
