#1 |
Has anyone noticed a whining/bird like sounding sound when you have your a/c fan on low. My 04 Ion did it and now my new 06 is starting it. I haven't checked to see if it is a common complaint, just wondering if anyone else noticed that off hand.
Former Saturns: 2006 Ion 3 2.4L, 5 speed 2004 Ion 2, 5 speed; 2004 Vue, 5 speed 2002 SL1, 5 speed; 1993 SC1, 5 speed |
#2 | |
![]() Quote:
#3 |
![]() ![]() Join Date: Jan 2006
2002 SC1
S-series do it too. Turn the radio up.
Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy. |
#4 |
![]() Join Date: Jan 2005
The only new fan noise i've noticed is after I've been playing a CD. When I park the car, eject the disc, turn off the stereo and move to switch off the ignition, I hear a very low humming sound. Maybe it's the car's cooling fans but it sounds too low-pitched for the "hair dryers" as I call 'em.
My '04 had a CD player too and I can't recall ever hearing it make this sound but it made plenty of its own bizarre noises. If this is the weirdest sound my '06 makes, I'll consider myself very fortunate.
2015 Buick Verano Turbo 5 - 2006 Ion 3 Sedan, Manual, Storm Grey 4 - 2004 Ion 2 Sedan, Manual, Electric Blue 3 - 1996 SL2 Manual, Medium Red 2 - 1991 SL1 Manual, White 1 - 1991 SL Manual, Grey |
#5 |
![]() Join Date: Jul 2004
2008 AURA XE
2006 VUE 2.2L
The sound you describe is not uncommon for some IONs. There have been more than a few comments made about it on here in the past. My 04' use to make that same chirping sound when on low speed. It never was very loud, just annoying. My fix was to turn the fan speed up a notch, which usually made the sound go away, and then I'd turn it back down if needed a few minutes later. Eventually, the sound just seemed to disappear all by its self...maybe by wearing in, what ever was causing it. A few people on here either had a extra loud one or were over sensative to the sound and had their retailer replace the fan motor. I just waited mine out.
"The principle difference between a man and a dog is that if you take a dog in and make him prosperous, he won't bite you!" - Mark Twain 2008 Aura XE-4 2006 VUE 2.2L |
#6 |
![]() Join Date: Feb 2000
You may want to bring it to your retailer if its in the 3-36 warranty period. There is a bulletin that pertains to this issue. Your retailer can install a cap on the blower motor to deaden the sound. If not in 3-36 I wouldn't recomend it The price far outweighs the benefits. Bulletin #04-01-37-008
~ If it worked before you messed with it, it must be something you did ~ |
#7 |
![]() Join Date: Mar 2006
2004 ION-2 Sedan
Yay! I'm not crazy!
International Order of Ninjas |
#8 |
Bring it to your local dealer and tell them that you have a squeel on loww blower speeds.Because the way the HVAC case was desighned they will have to cut the case to remove the blower motor.But their is a fix to your problem.
#9 |
I say it's not worth it, since you never really notice it unless you have the radio off and you're searching for it. Mine does it too, always has. I like it.
2003 Saturn Ion 2001 Mazda Miata 1997 Saturn SC1 |
#10 |
![]() Join Date: Dec 2003
2004 ION-2 Sedan
The dealer "fixed" mine a few months back per the TSB. Started again last week, I'm just going to pretend it's a fan on indicator from now on.
#11 |
![]() Join Date: Feb 2005
2005 ION-3 Quad Coupe
My fan is pretty quiet, unless I turn it on and it's really cold out.. Then it makes a god aweful grinding/chirpping noise..
Red 2005 Ion-3 coupe |
#12 | |
![]() Quote:
Mine is pretty quite also unless I turn it on. ![]() |
#13 |
![]() Join Date: Feb 2006
2006 ION-3 Sedan
I dont really have a "chirping" sound. I just get what sounds like a normal whistling sound when on low that gets higher pitched as the engine is revved up (probably since the alternator is making more power).
Ion 3 Sedan with 2.4 liter engine stock "Weekends here, good god almighty people, lets get drunk and be somebody" |
#14 |
2006 VUE Red Line
2007 ION-3 Sedan
my 06 sounds like there is a bad bearing or too much slop in the shaft, but only on low speed, will probably need a new motor. best get any problems fixed during warranty or it may be customer pay later
#15 |
2003 ION-1 Sedan
2006 ION-3 Sedan
first check if there is debree in the air inlet in the cowl behind the wipers.
Then check your a/c air filter behind the glove box. Then you have to remove the motor but you have to carefully cut it out and get a kit from the dealer to reinstall whether its the old one or a new one. Theres a service bullitin open for these vehicles. I am a mechanic and have the manuals for the ion. I'm also having the same problem. Just gotta find time to do it myself
Low budget audio is the way to go |
#16 |
I know exactly the sound that you are referring to. I remedied the situation by taking out the blower motor and putting white lithium grease on all the moving parts of the motor. Then cleaning out all of the vents.
#17 |
![]() Join Date: Apr 2004
How did you remove the motor without having the dealer's replacement kit?
On the Ions, you have to literally cut the motor out of the HVAC unit, and then screw it back in with a dealer-only ring with 6 screws. Once you actually have that ring (that is, once the motor has been replaced once) it's easy to do, but the cars don't come from the factory with those metal rings installed. |
Bookmarks |
A/C will only work on low fan speed | JSLACH | Vue Tech | 30 | 07-01-2020 08:10 PM |
Funny sound at low RPMs. | house | S-Series General | 0 | 07-20-2006 04:45 AM |
Low Groaning/Growling Sound | 2NDSOUT | S-Series Tech | 2 | 01-29-2006 11:27 AM |
does this sound like a bad fan relay? | infernalservice | S-Series General | 2 | 09-15-2005 02:15 PM |
AC/Heat Fan Stuck on low | pmheart6 | S-Series General | 1 | 08-09-2004 10:51 PM |
