Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 01-28-2005, 09:02 PM   #1
cottonfox
cottonfox is on a distinguished road
Default L series 3.0 oil leak
My 2000 LW300 (60,000 k) has developed an oil leak. The oil seems to be dripping in the area of the long bolts on the oil pan close to the flywheel. I have been told it may be the rear main seal. A local Saturn mechanic says rear main seal leaks are common (he says he has two L series 3.0 in the shop now each with a rear main seal leak...this was a telephone conversation he
has not looked at my car). One of the forum members says he has never heard of this particular engine having rear main seal leaks. I would appreciate any information or experience anyone has had with this problem...
or any other ideas as to the source of this leak.
cottonfox is offline
Old 01-28-2005, 09:58 PM   #2
hugh
hugh will become famous soon enough
Default Re: L series 3.0 oil leak
Suggest you post on Tech Talk where you should get a much faster response from the Techs who reside there.
hugh is offline
S- Series Transmission Leak actnbill S-Series Tech 10 11-07-2007 10:43 PM
SL2 oil leak & Rear oil seal kit parts id jimmmm S-Series Tech 1 10-25-2007 02:50 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
L-series 3.0 oil leak cottonfox L-Series Tech 0 01-28-2005 10:27 PM
Oil Cooler Housing Leak on L-series V6 ! Yankeez L-Series Tech 5 12-11-2001 11:54 AM
