#1 | |
![]() Join Date: Nov 2006
2003 ION-3 Quad Coupe
hey,
my wife's car is acting a little strange this winter. Ive been noticing that intermittently the starter will stay engaged even after the car has started and the key is no longer in the "crank" position. Also, twice the car has failed to start. It will start to crank for an instant then stop. the first time, the security light was flashing and the LED display said, "service vehicle" or something like that. i did a little searching and found this in this forum... Quote:
#2 |
![]() Join Date: Feb 2000
Yes there is a TSB #04-08-45-005D.
Yes it sounds like your vehicle may have that issue.
~ If it worked before you messed with it, it must be something you did ~ |
#3 |
thanks, that sounds like my problem.
#4 |
![]() Join Date: Jan 2006
1991 Astra XE
1991 AURA XR
CHeck your battery cables first. I had this problem, but then it came back. However this time, my ground battery cable was loose and severely corroded. 99% chance its the ign switch though.
Bookmarks |
96 SL starting problems | TeddyKGB | S-Series General | 4 | 07-24-2009 10:28 PM |
ION Quad Coupe starting problems help!!! | beyondink | Ion Tech | 2 | 12-08-2006 11:19 AM |
Starting problems | Jamzie | L-Series Tech | 1 | 09-21-2006 07:44 PM |
Starting Problems | oneharbour78 | S-Series Tech | 5 | 06-17-2005 10:58 PM |
2004 ION starting problems when cold | sherman | Ion Tech | 3 | 01-24-2005 09:18 PM |
