#1 |
The other day someone was drifiting over into my lane and went to honk the horn......no horn sound. All I felt was the cover popping in and out. After I got home, I tried to honk the horn. Guess what.....no sound. I pushed it over the horn symbols, the center, all over. I finally got it to honk but had to push really hard to activate it. Has anyone else had this problem?
John |
#2 |
![]() Join Date: May 2004
2004 ION Red Line
2002 L-Series 3.0L Sedan
The horn on the Relay honks best by pressing on the top center of the horn asm
Does not seem to be the right thing but at least it will work every time if you do it this way. |
#3 |
![]() Join Date: Jul 2005
Mine does it intermitantly! push some times , it works , others it dont!
#4 |
![]() ![]() ![]() ![]() Join Date: Aug 2001
2007 AURA XR
2008 Astra XE
The POS on the L-series has the same problem.
Unless you hit the the lil horn symbol DEAD CENTER, you have nothing. Some safety device, eh? ![]()
93 SW2 96 SL2 01 SL2 02 L200 08 Astra Xe 07 Aura XR Complacency leads to mediocrity. Mediocrity leads to our demise. |
#5 |
![]() Join Date: Feb 2002
Brand new bulletin just came out. Apparently had an issue where some Relay's received stiffer horn springs then spec'ed. Ask your retailer about it - it's pretty new, this week I think.
#6 | |
![]() Join Date: Apr 2005
![]() Quote:
Brandon |
#7 | |
![]() Quote:
#8 |
![]() Join Date: Dec 2005
I have the same problem, as well as many others.
#9 |
![]() Join Date: May 2005
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
It's just like Chrysler. They've had problems with junk ****** clocksprings since forever. Apparently so does the Relay. Not a big deal, there will be a recall. Trust me. We have like, 14 different clocksprings we keep in stock here because stuff breaks. Get used to clocksprings breaking. They're about as bad as 3 dollar tires from walmart.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget. "1G8ZF5594PZ249184"-Trinity, for three are now one. |
#10 |
![]() Join Date: Feb 2000
#05-08-54-001A High Effort to Sound Horn, Horn Only Sounds When Certain Spots are Pressed (Replace Horn Pad Springs) - (Oct 21, 2005)
~ If it worked before you messed with it, it must be something you did ~ |
#11 | |
![]() Quote:
Thanks tech! Less for me to look for! |
#12 | |
1993 SL2
1991 SL2
![]() Quote:
#13 |
![]() Join Date: Jan 2006
2008 VUE 2.4L
We had this issue when we first got our van...they changed the airbag and no more problems. Easy fix.
#14 | |
![]() Quote:
-Blue 06Vue v6 awd. -95VW Rally-xer, built for sweet jumps. -89 VW Cabriolet. |
Bookmarks |
Need another PCM to activate my Cruise Control | kksport | S-Series Tech | 18 | 12-04-2007 11:35 AM |
re-activate alarm? | saturnhouse | S-Series Tech | 2 | 06-25-2007 02:15 PM |
How did your ABS activate? | fdryer | General Saturn Discussion | 4 | 09-06-2006 07:51 PM |
Where to find, a hard to find, 98 SL1 replacement horn with 3 terminals? | 2002SaturnMan | S-Series General | 1 | 04-02-2006 11:20 PM |
ION Horn, hard to find, press & little sound | cfoell | Ion General | 21 | 02-21-2005 11:18 PM |
