Old 05-16-2021, 10:45 PM   #1
Lightfoot2002
Lightfoot2002 has a spectacular aura aboutLightfoot2002 has a spectacular aura about
Default I had to do it! It had to be done!
Hello all! For quite some time after it rains the spare tire wheel well in the trunk fills with water. Every pick up truck that I know of has a round hole in the truck bed to let any water escape. So, I drilled a 1/4 dia hole thru the spare tire trunk well to let any future water escape. I chose the lowest point to make the drill thru. I noticed a rectangular access plate on the well floor but its purpose is uncertain.
I am very thankful that I own this 2002 SC2 5 speed manual coupe. It has a distinctive sporty appearance. I was stopped at a stop light the other day and I noticed another driver taking a photo of my Saturn! With very frugal driving I still get in the upper 30's for around town/suburban driving. Many modern SUVs have to shell out a heck of a lot of money to fill up.
A previous owner swapped in a SC1 5th gear into my 02 SC2 5 speed. It knocked out my cruise control but I don't care.
Lightfoot2002 is offline   Reply With Quote
Old 05-17-2021, 12:23 AM   #2
Waiex191
Waiex191's Avatar
Default Re: I had to do it! It had to be done!
My '98 SC2 also has a couple drain holes drilled in the trunk.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-17-2021, 07:44 AM   #3
dummo
dummo's Avatar
1997 SW2
Maybe glue an exterior flap of rubber sheet material that loosely covers the hole from the underside -or even better a reverse miniature hood scoop that protects the hole from the elements especially while the vehicle is in motion.
... and, of course, paint the exposed metal edge of the hole.
1994 SL1 new traded
1992 SL2 new traded for above
Old 05-17-2021, 09:11 AM   #4
onlinebiker
I found a novel way to keep the trunk dry.
Park inside...
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 auto
01 SC2 5 sp
02 SC2
02 SL2 auto
02 SL2 5 sp
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 05-17-2021, 09:25 AM   #5
dummo
dummo's Avatar
1997 SW2
^^^^Ask your wife if you can move the couch.
1994 SL1 new traded
Old 05-17-2021, 11:02 AM   #6
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Hope you painted the hole after drilling. Even a small just a small one, exposed bare metal could cause rust to start forming and spread to the entire wheel well. Would certainly take a while, but is something to thing about assuming your location is right.
97 SL2, auto, 123K miles
Old 05-17-2021, 01:41 PM   #7
Drill a hole? Why? Every S-Series I've owned has had a body plug already in the spare tire well.
If your trunk is getting that much water in it, you have a leak that should be fixed by replacing the crap factory installed seam sealer, not drill holes in the car. The rear body panels come off much more reliably and safely than the door panels.
Old 05-17-2021, 04:35 PM   #8
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
While I won't say it was wrong to drill the hole, I would be searching for the reason why you have the leak in the first place. It runs the risk of getting moldy and even causing issues in wiring. The wires don't even need to be IN the water to develop problems.
I'd place a camera in the back and record while you hose down the trunk with water to see where it's coming in at. It might be something as simple as needing a new seal, perhaps a body panel is loose OR you might have a bad window gasket.
Check out my current SL1!
http://www.saturnfans.com/forums/showthread.php?t=268456
cujoe_da_man is offline   Reply With Quote
Old 05-17-2021, 05:30 PM   #9
Waiex191
Waiex191's Avatar
Trunk leaks are a common problem in Saturns and generally are traced to sealant issues on the unibody, under the plastic quarter panels. So yes you can take them off and fix it properly. Takes some time. Drilling a few holes is super fast. So currently I've got unpainted holes and will fix it correctly when I have it apart to rebuild.
Originally Posted by Waiex191 View Post
Borrowing 1993's picture. Does that square hole to the right of the tire give me the access I need?
Bryan Cotton
Old 05-17-2021, 08:51 PM   #10
cujoe_da_man
It just reminds me of Fiero's, they look so naked without their body panels on!
Old 05-18-2021, 03:13 PM   #11
Here's a thread for the OP, specific to 3rd gen coupes with pictures
http://www.saturnfans.com/forums/showthread.php?t=78228
My 2002 SC2 has a rubber plug on the rear driver side "cubby" in the trunk, that has a cross-slit in it that a couple of wires run through. Because the plug is slightly raised from the surrounding metal, I added a strip of cloth to help drain the area.
I cut a strip of old T-shirt, couple of inches long by maybe 1/4" wide. I pushed about 1/2" ~ 1" of it through the slit so it hangs down. The rubber cross slit holds that in place. I also put a small magnet to hold the other end down to the bottom of the cubby. It wicks up any water and drains down the other end hanging down (not visible from outside the car). Beautiful day out today so I went out and took a pic
I've got it mostly fixed properly and it stays dry most of the time, but if it rains super hard and for many hours, i might get a little bit of water on the passenger side cubby, no more than 1/4" deep so far - spare tire well stays dry (used to get flooded) and the T-shirt does its job wicking away water. So, I might just drill a hole in the passenger side for now rather than trying to trace a minuscule leak.
edit: ignore the extra wiring in the pic, PO bypassed the original wiring to add LED brake and turn signal lights. They were terrible and brake lights were barely visible during the day. I restored the original lights and bulbs but kept the wiring as I might connect them to light up the center reflector bar eventually.
