Old 05-05-2021, 02:42 PM   #1
Steve4637
Steve4637 is on a distinguished road
Default 5spd Transmission problem 1998 SL2
Hello ---- I'm hoping to get some help/ answers here.
I have 98 SL2 5spd.... I've had it 5 years.. and honestly been one of the best cars I've owned in 40 or so years
Just this morning after driving about 45 miles to an appointment, I got back into the car to drive home....and when I started it up and put it in 1st gear and let out the clutch, it felt like I was almost in 2nd or 3rd gear and it took off really slow. The car drove home fine, shifting through all gears, one to five with no problem and no clutch slippage...but once again, pulling off the interstate at a stoplight and going back to first gear....it takes off slow again like it's in 2nd or 3rd gear. The car has 280k and had the clutch changed at 242k
Can any of the gurus here give me an idea of what might be happening? I really like the car and have become a little attached to it as it's never let me down.
Thanks in advance!!
Steve4637 is offline   Reply With Quote
Old 05-05-2021, 02:50 PM   #2
Waiex191
Waiex191's Avatar
Default Re: 5spd Transmission problem 1998 SL2
Maybe you have a shift cable failing - and you are getting 3rd instead of 1st. I'd pop off the console and have a look.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-05-2021, 03:01 PM   #3
billr
Watch the tach to see if it really is going into a gear other than the 1st intended; or if the engine is running weak but the trans is properly in 1st.
Old 05-05-2021, 03:10 PM   #4
Steve4637
I will take a look at the tach....but I was driving back at 80mph passing easily.....so the engine has tons of power and no noises or slippage.
When I replaced the clutch at 242k it was slipping in every gear. This feels like a whole different problem
Old 05-05-2021, 03:30 PM   #5
Is the catalytic converter original?
Old 05-05-2021, 04:25 PM   #6
billr
Power at 80 (I assume that isn't in 1st!) isn't important. We need to find out if the problem in 1st is because of a wrong gear or because of power loss. We will be looking in totally different directions, depending on the answer to that.
Old 05-05-2021, 08:56 PM   #7
Steve4637
Yes it is the original...and it actually has the check engine light on with a code saying the converter is a problem. But it's been like that for about 7 months and never caused any drivability issues.
Old 05-05-2021, 08:58 PM   #8
Steve4637
Thanks for all the help so far!!
Old 05-05-2021, 10:28 PM   #9
The catcon can disintegrate internally, blocking exhaust flow intermittently or continually. Goggle catcon design, a high temperature porous ceramic substrate. An expensive porous brick to convert exhaust gases until it falls apart. Some hear rattling like marbles, others rap it and hear loose cat guts when it's not supposed to have anything loose within.
The simple test at home is to remove the upstream exhaust manifold mounted O2 sensor for an alternate exhaust path before the catcon. You might have to use a temporary soup can diverter to divert hot exhaust gases away from plastics or radiator. Exhaust will be loud but if power returns suddenly after sluggish acceleration, this can help verify a damaged catcon. Ignore the error code generated from the sensor.
Old 05-06-2021, 12:21 AM   #10
Waiex191
Waiex191's Avatar
If it's got power at 80, it is unlikely to be the catcon. I'm still predicting shift cable issues.
Bryan Cotton
Old 05-06-2021, 05:50 AM   #11
Steve4637
Hi Bryan --- You very well could be correct as it truly feels like I am taking off in 2nd gear instead of 1st.
Also I've had the car up to 90 in the last two weeks and 80 yesterday.....so it definitely has tons of power
Is the cable problem an easy fix?
Old 05-06-2021, 10:27 AM   #12
Waiex191
Waiex191's Avatar
Steve,
Search for "shifter cable bushing" on the forum. I've not had to do it yet but others may chime in.
One cable works left to right. If it breaks you only get 3rd and 4th. Or if the cable/bushing are compromised you may get loss of motion and that could be why you are not getting first.
One cable works front to back. That lets you shift 1-2, or 3-4, or 5, or R depending upon the left-right position.
You have to take off the console to look at the shift tower and the related bushings. Just a bunch of screws.
Bryan Cotton
Old 05-06-2021, 08:34 PM   #13
Steve4637
Steve,
Bryan --- Thanks buddy. I now believe you are correct. I drove the car today and I'm almost 100 percent sure that I am some how starting off in second gear, while the shifter is actually in 1st gear. Something definitely wrong. I am going to have someone a lot more mechanically inclined take a look
Old 05-08-2021, 10:48 AM   #14
For the mechanically uninclined, Saturn S series owner let me introduce you to your new best friend, richpin06a.
Step by step showing how to remove the center console and replacing the shifter bushing (if the bushing turns out to be the problem.
https://www.youtube.com/watch?v=AI3h7uSTvAI
richpin has a ton of videos, very thorough, that includes info like tools needed, where to find the part, what you need to remove to get to the part, etc. (a lot of places start off with closeups of the part, all the stuff already removed, and you have no idea where to begin to find the part)
I've seen a video of his where he just shows the shifter being shifted through each gear but couldnt find it
Saturnbushingman (Jerry Borshard) on ebay has delrin and stainless options on ebay, also goes by saturnbushinghennie and saturnbushing(something, dont recall off hand) for lower cost options.
alternate video by jungleking
https://www.youtube.com/watch?app=desktop&v=XFdEt6POnco
Old 05-08-2021, 04:57 PM   #15
Steve4637
Thank you.
I actually had it semi-repaired this morning. It definitely was the cable, but it was the cable bushing next to the transaxle instead of the other end under the console.
The guy who fixed it says I should get new shifter cables as he said they are worn out. He recommended I find some new cables instead of used ones from a wrecking yard. He said I also need a new clamp
Has anyone used any aftermarket cables, like those from RockAuto?
Old 05-08-2021, 05:26 PM   #16
Waiex191
Waiex191's Avatar
I've heard the aftermarket ones are low quality, and used ones from the junkyard is the way to go.
Bryan Cotton
Old 05-08-2021, 07:45 PM   #17
Steve4637
Bryan --- Do you know if the bushing is the same for both ends of the cable?
I also read about a guy named Hein that makes new cables -- is there any way to contact him?
Thanks
Old 05-08-2021, 09:40 PM   #18
Waiex191
Waiex191's Avatar
Heins 's website is here:
https://diyvan.com/
I thought he was done with Saturns though.
I think the ends are different, but it has been a while since I played with them.
Bryan Cotton
Old 05-08-2021, 10:07 PM   #19
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
That would be hard since the gate is in the transmission. I doubt youd notice that you moved a bit to get to the gate.
Old 05-08-2021, 10:08 PM   #20
RobertGary1
True. I tried the aftermarket steal bushing snd had several fail. Got a junk yard one and its great. Looked newer.
5spd transmission fluid sw87 S-Series General 14 02-06-2011 06:12 PM
1998 SC2 transmission problem harley2003 S-Series General 3 04-16-2010 10:00 AM
1998 Saturn SL2 Transmission problem jpoell01 S-Series Tech 7 09-04-2009 01:56 PM
1998 SL1 Auto Transmission Problem Spreck13 S-Series Tech 2 03-31-2008 01:34 PM
WTB: 5spd Transmission Madson26 Classifieds 7 08-10-2005 08:40 AM
