Old 05-08-2021, 01:49 AM   #1
sc2 saturn
sc2 saturn will become famous soon enough
Default belt question
01 sc2 i installed a metal pulley on the Tensioner so 90mm compared to oem 76mm dia, went to install my new belt after doing my alternator bearing it measures 77.76 inch or 1975mm and i have hardly any movement to loosen belt maybe 1/8 if that and it was very close to my crank pulley, but my worn out belt that has a small pin hole in it, i have about half inch movement roughly is it normal to have that close tolerance to crank pulley with bigger dia tensioner pulley with new belt? i looked rock auto and all there belts with A/C P/S Etc is all same size that, been my tensioner is close to crank pulley dose that matter any? been the belt comes off crank to tensioner alternator p/s idler water pump and ac?
sc2 saturn is offline   Reply With Quote
Old 05-08-2021, 09:41 AM   #2
Default Re: belt question
The belt diagram should be on the radiator support. Same routing on both SOHC and DOHC, though I believe the optional "no power steering pump" has the belt over the idler rather than under it.
There's likely a clearance issue with the larger pulley which is why it's got so little movement. You'll also need a different length belt than OEM, I think it was a 77.8" belt instead of a 77.5" (could be a totally different size, likely need to use twine to get a close measurement and then get 2+ belts from the parts store). Yes, that little bit is the difference between a belt that fits properly and one that has the tensioner knocking while the engine is running.
Old 05-08-2021, 01:06 PM   #3
billr
The 90mm is the OEM, not the other way around; and it has plenty of clearance to a stock crank pulley (about 1/2" or more). Well, "plenty" for the engine to operate, maybe those smaller pulleys or longer belts came about to aid "5-minute" belt changes? A stock 778/1975 belt will fit.
Old 05-08-2021, 05:32 PM   #4
sc2 saturn
oem for me was the 76mm and i upgraded to 90mm i tired to use the belt i got 2 years ago which is brand new ac delco 5k778 unfortunately every website i checked for a belt there all same size 77.79 length which gives only like 1/8 roughly for tensioner to move and looks like its touching crank or its very close to be touching is there any other saturns that use a longer belt then a 77.79?
Another Belt question.. 01 sc2 timl865 S-Series Tech 7 08-24-2018 08:21 PM
Belt Question dcc81187 S-Series Mods 7 01-19-2010 05:08 PM
belt tensioner question 95 sl1 drako markam S-Series Tech 0 05-18-2009 10:44 PM
Belt Question Helltime S-Series Tech 1 03-02-2009 08:02 PM
belt question again 00satSC1 S-Series Mods 6 10-15-2006 03:25 AM
