Old 04-30-2021, 07:34 PM   #1
Undertake72
Undertake72 is on a distinguished road
Default 1998 sc2 tach issues
Ok so here I am again .. But I got a different tach that atleast reads something ... Now I have a autometer model number 2300 tach for my pure stock car ... I called autometer and they assured me that it will work and told me pin 2 " white wire" on the light blue connector .. I tried that and have the tach set to 4 cyl ... And it only reads half the rpm straight from the pcm ... What is going on here ???? I cant for the life of me figure this out .. Does anyone have any better / any info at ill that can help me ??? Any help is much appreciated !!!!
Undertake72 is offline   Reply With Quote
Old 04-30-2021, 07:41 PM   #2
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Default Re: 1998 sc2 tach issues
While I don't personally know much about how the aftermarket gauges/ECUs work with these cars, I have heard that getting tach reading can be a pain. Hopefully someone else can chime in but I remember hearing you have to double the cylinder count in software (and probably some other things) for it to work. Something to do with the waste spark system making things tricky I think.
97 SL2, auto, 123K miles
Old 04-30-2021, 07:50 PM   #3
4cyl + waste spark = 8cyl tach signal
Old 04-30-2021, 09:04 PM   #4
Undertake72
So I tried the 8 cyl option on the tach and it reads at a 1/4 of the engine output !!! Now what????
Old 04-30-2021, 09:22 PM   #5
Set it to two cylinder...
Old 05-01-2021, 12:09 AM   #6
Well, that isn't going to work! I peeked at the (poor) literature for the 2300 on their web-site. It is only for 4, 6, and 8 cylinder engines. More important, it is only for single-coil engines with a distributor. It looks like the Autometer #9117 "Tach Adapter" can mate that to the Saturn wasted-spark ignition.
1998 sc2 tach siganl Undertake72 S-Series Tech 1 04-24-2021 12:05 AM
Speedo and Tach issues Ericth4 S-Series Tech 5 05-01-2011 08:27 PM
got a 1998 SC2 - some issues. genewitch S-Series Tech 41 05-17-2010 07:24 PM
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 06:11 PM
1998 sl2 performance issues njsarge S-Series General 13 05-15-2009 09:04 AM
