Old 01-27-2021, 03:02 PM   #1
Tamburitzan
Tamburitzan is on a distinguished road
Dizzy 2006 Saturn Vue.
I have an interesting problem. When it is cold, the vehicle starts and runs but the instrument gauges and lights do not work, no odometer can be seen. Sometimes it doesn’t turn over until I turn the key a few times to start. The radio is also blank. It can be driven but the power steering doesn’t work and steering is hard. When it warms up. I shut the engine off and restart it. Engine fires up quickly and everything works. Instruments, lights, radio and power steering like the problem doesn’t exist.
Tamburitzan is offline   Reply With Quote
Old 01-28-2021, 06:21 PM   #2
Default Re: 2006 Saturn Vue.
Starting in 2000, Saturns added an additional body control module (BCM) that runs almost everything unrelated to the engine and xmission. All interior/exterior lighting, gauges, indicators, factory security, and gateway for on board diagnostics for the OBD II system. Airbags and anti lock brakes have their own modules. If I'm not mistaken, these modules are basically programmable logic controllers (plc) for automatic power on self tests before operating. If a self test fails, either the engine or wrench indicator turns on with a stepped error code.
Your descriptions seem to fit possible bcm issues. Review any threads within Vue forums about electrical/electronic issues. One in particular may be wet connections to the bcm resulting in corrosion leading to erratic symptoms.
Old 01-28-2021, 07:09 PM   #3
Tamburitzan
Thank you very much
Old 02-03-2021, 04:47 AM   #4
nickson
nickson is on a distinguished road
Use a scanner to see if any trouble codes come up.
nickson is offline   Reply With Quote
Old 03-10-2021, 11:22 PM   #5
galeon89
galeon89 is on a distinguished road
Were you able to resolve the issue?
galeon89 is offline   Reply With Quote
Old 03-11-2021, 04:23 AM   #6
Tamburitzan
No. It still has the same intermittent problem when it is cold outside
2006 Saturn Vue is no more hoosierrun Vue General 3 11-04-2017 06:35 AM
2006 Saturn Vue FWD bbake516 2008 Vue 4 01-06-2016 08:51 PM
2006 Saturn Vue V6 olorenzo11 Vue General 2 06-22-2015 06:05 PM
2006 2.2 Saturn ION jcc007 Ion Tech 6 01-09-2012 02:29 PM
2006 Saturn Aura at Saturn of Green Bay, WI mjbuck Aura General 0 08-27-2006 12:08 AM
