Old 06-21-2011, 08:00 PM   #1
Quickstreet
Quickstreet is on a distinguished road
Default 2005 vue a/c problems
My buddy's 2005 Vue A/C is not working properly. The pressure is high, however the unit does not blow cold air and as the outside temp rises? so does the inside vent temp. We were going to try and refill the system but it seems the pressure is showing on the high side of full (or green). There seems to be a lot of oil in the system also? This unit has not been serviced as yet by anyone! Any ideas would be appreciated. We need to get it fixed and just don't want to get raped by a mechanic or service center here in southern FL. Someone has mentioned having it emptied and refilled using a vac system? all help appreciated thanks
Quickstreet is offline   Reply With Quote
Old 06-21-2011, 08:28 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: 2005 vue a/c problems
first off, this is the S-series forum. the Vue forum I believe is just below the S-series ones.
next, I believe you'll need a recharge/recovery unit to recover any A/C left in your system -- means $$$$.
also, those gauges on the refill cans mean jack squat. you should be able to get a decent set of A/C gauges at harbor freight for a good price.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
2005 Saturn Vue problems mcanous Vue Tech 2 04-18-2011 03:11 PM
Major 2005 Vue Problems dronshaw Vue Tech 2 07-08-2009 07:27 PM
New-to-me 2005 VUE- Problems already- only Day 2! joshjani Vue Tech 11 03-12-2009 04:48 AM
2005 VUE Radio Problems 2NDSOUT Vue Tech 3 09-30-2006 06:09 PM
Problems with Catalytic Converter-2005 2NDSOUT Vue General 7 08-13-2005 11:56 PM
