Old 04-13-2013, 10:23 PM   #1
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Default A/C valve core tool
The A/C valve cores on the Vue have this odd big ball on the tip. I have several A/C core drivers but none can get over this odd end. I've not seen this in the other Saturn A/Cs I've worked on. I think I loosened the low side a bit because my gauge set spins as they depress the cores. Normally I just verify both cores after removing the gauges.
Is there a "fat tip" core tool for the Vue?
Btw I bought the $120 rebuild kit last summer when my compressor went out. It included the dryer, compressor and the TXV. Fired the system up for the first time this year and it was freezing cold. This is the third kit I've bought from this company and all have worked well. It's Chinese gear.
-Robert
Old 04-13-2013, 11:39 PM   #2
Default Re: A/C valve core tool
So much for the naysayers about Chinese made products.
Tried Googling for valve core tools? Drill your valve core tool to a larger diameter?
Heater Core Shut-Off Valve? bumpdraft S-Series General 23 12-11-2011 07:47 PM
A/C valve core replacement ChadDISCSaturn General Saturn Discussion 2 07-18-2010 12:56 AM
Valve spring tool almoore S-Series Tech 1 04-01-2010 12:41 PM
Need pic of cam sprocket retention tool and valve spring removal tool sr20fd3st S-Series General 2 07-13-2009 10:41 PM
A/C Valve Core mirandm S-Series Tech 4 09-03-2006 02:32 PM
