Old 07-31-2008, 05:36 PM   #1
briansc1
briansc1 is on a distinguished road
2002 SC1
Default remanufactured trans & engines
Has any one bought any remanufactured trans and or engines for S series cars? What kind of luck have u had?
thanks
briansc1 is offline   Reply With Quote
Old 07-31-2008, 06:20 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: remanufactured trans & engines
I remanufacture my own.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 07-31-2008, 06:27 PM   #3
Ohming
Ohming is on a distinguished road
Ohming's Avatar
1995 SC1
The best quote I got for a rebuilt was "about $2000", with me bringing him the engine. Most of these cars discussed here are $1500-3500 cars. That's easy math. (transmission not included)
95 SC2 A/T
97 SC2 M/T
Ohming is offline   Reply With Quote
Old 07-31-2008, 07:03 PM   #4
MikeNW
MikeNW is a glorious beacon of lightMikeNW is a glorious beacon of lightMikeNW is a glorious beacon of lightMikeNW is a glorious beacon of lightMikeNW is a glorious beacon of light
MikeNW's Avatar
1997 SL
Success depends on whether the person who rebuilt it knew what they were doing. You could end up with a substandard product that will run OK until the warranty is over. Where a good product might have run fine for 100,000 miles or more.
You should have some reason for trusting them.
If I didn't have someone like Low Saturn near by, and the car was otherwise in good shape, I would have to get a Saturn crate engine and install it myself.
97 SL. Bought 7/07, reluctantly sold Dec 2019
Burgman 400- indestructible beast
Sportster 883- fun bike
Cannondale 29er- daily driver
Old 07-31-2008, 07:27 PM   #5
MikeNW
MikeNW's Avatar
1997 SL
ooops
Old 07-31-2008, 09:11 PM   #6
sc2dohc94
sc2dohc94 is on a distinguished road
1994 SC2
i live in dallas tx area i took my engine to city motor supply and had it rebuilt for $500
sc2dohc94 is offline   Reply With Quote
Old 07-31-2008, 10:50 PM   #7
Low Saturn
Low Saturn's Avatar
2007 AURA XR
They rebuilt the engine for $500?
Rings, pistons, bearings and gaskets come to more than that.
Mike
-1991 Turbo SL2.
Old 07-31-2008, 11:04 PM   #8
fujioko
fujioko is on a distinguished road
fujioko's Avatar
1996 SW1
So far I have spent $540.00 on an in frame rebuild on my 96SW1. I’ll need to spend another $35.00 for fluids.
The best part is I know the job was done right and the pistons will have the drain holes. I done think most rebuilders would modify the pistons.
96 SW1 5spd & trailer hitch 309000 miles <--rebuilt!
79 Triumph Spitfire <--British car
94 Mazda Miata 45MPG
91 Mazda Miata 3 cyl. 51MPG
fujioko is offline   Reply With Quote
Old 07-31-2008, 11:49 PM   #9
Crasoum
Crasoum will become famous soon enough
1993 SL2
Probably just a short block, I have a place local that does short block for $519. I know Blaine Motor Supply in Dallas does them even cheaper. To be honest I don't know the quality however, and am currently dealing with head-work that is nickel and diming me to death from my local shop.
They make their money back in all the small stuff it seems.
Crasoum is offline   Reply With Quote
Old 08-02-2008, 02:28 AM   #10
gkainz
gkainz is on a distinguished road
tell me more about an inframe rebuild? Do you have another thread on it somewhere? My son's 95 SL2 seems to have bit the dust and I'm contemplating what to do here - he can't afford another car right now...
gkainz is offline   Reply With Quote
Old 08-02-2008, 08:55 AM   #11
You do an in frame rebuild when you can not find an engine hoist. Just remove the head, timing cover, and pan. It is basically a new rings, valve job and valve seals, and a new timing chain set and oil pump.
Old 08-02-2008, 01:49 PM   #12
gkainz
I don't have a problem with pulling the engine if necessary. However, if not necessary then that would be cool, too ... my engine experience is limited to older V8 engines, so this is new to me.
Swapping engines 94&95 Shagadoodle S-Series Tech 7 04-26-2009 07:57 PM
92 SL2: Cardone remanufactured rack & pinion has L & R tie rods swapped; what to do? onixwj S-Series Tech 2 04-20-2009 01:55 AM
94saturn & 96saturn engines 96 saturn S-Series General 1 03-09-2005 05:13 PM
2.2 & 3.0 engines on eBay silverblueL200 L-Series General 4 02-23-2004 08:13 PM
Transmissions that bolt up to the Saturn 1.9 & 2.2 engines applebit Mods and Performance 8 10-22-2003 09:26 PM
