Old 08-02-2021, 07:10 PM   #1
rjc862003
rjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the rough
Default 07 ION what to watch out for
going to look at this specimen https://www.facebook.com/marketplace...26255012022316
tomarrow
any obvious pitfalls to watch out for I read something about the VTI CVT trannys being bad to middling but I am pretty sure they stopped making them by 2005
rjc862003 is offline   Reply With Quote
Old 08-03-2021, 07:13 PM   #2
ruley73
ruley73's Avatar
Default Re: 07 ION what to watch out for
Make sure the A/C and radiator cooling fan work. The AC compressor and cooling fan motors commonly fail. Listen for clunks from the front end (lower control arm bushings) and rear end (rear axle bushings) during the test drive. If it has a sunroof, look for water stains in the headliner.
2007 Chevy Equinox LT 203K miles
2018 Chrysler Pacifica Touring L 68K miles
Old 08-03-2021, 10:08 PM   #3
rjc862003
Default Re: 07 ION 3 Quad what to watch out for
made a deal I couldn't refuse does have P0411 code which is likely from the blown gasket between the cat and the resonator, fixed the leak and cleared the codes fingers crossed
no bad sounds from the suspension yet rad fans and ac seem to work ok(a bit whiney but it hasn't been driven in 6 months
139k on the clock and runs strong plenty of get up and go
edit: I didn't realize until I ran the vin that its a ion 3
Old 08-04-2021, 07:26 PM   #4
ruley73
ruley73's Avatar
I doubt that gasket will fix it. DTC P0411 is usually caused by an issue related to the secondary AIR injection pump, check valve, or related plumbing. I've linked a corresponding parts diagram here.
Old 08-04-2021, 08:16 PM   #5
rjc862003
so far so good it passed the air injection test this morning after a cold start
taking it for its sticker tomarrow
I did pull the fuse out and clean it it wasn't to bad it was a little brown on the contacts fuse its self tested good, mabey that was just enough ?
it had been 730 something miles since its last code clear as well so might have picked up some gunk or like you said sticky check ball or a bad relay just happy to get it though
Old 08-05-2021, 08:49 PM   #6
rjc862003
inspected today all monitors set no lights
Old 08-17-2021, 10:53 PM   #7
rjc862003
still fighting a large evap leak and air injection code
I can hear the air pump running its excessively loud so I think its got a leak someware
the the vapor line looks pretty crusty so thats where I am going to start for the evap problem
being a PZEV car in ny has its perks ill take it up to the dealer and let them sort out the emissions bs
Watch This... blackbeard S-Series General 11 12-10-2013 05:14 PM
You all want to watch this. silv01 S-Series General 36 03-24-2013 03:30 PM
Watch out for bad CPS hholbein S-Series Tech 3 11-20-2010 05:04 PM
Anything to watch for in '02 SC1/2 Mr. Powers S-Series General 6 08-22-2004 12:20 AM
Vue Watch Out TL2282 Vue General 10 03-19-2002 10:50 PM
