Old 04-08-2009, 08:20 PM   #1
gorollover
gorollover is on a distinguished road
Default 2002 L200 - Hazard/Turn Signals not working. Plus driver's side brake light.
Just as the title says...
I decided today was a great weather day to finally replace my brake light until I realized we were sold the wrong bulb. Now, my rear left turn signal is not working... after fidgeting around with my father NONE of the turning signals work and neither do the hazards.
I have done some googling on the subject and have had a few referrals as to what to do but I would like to ask once more!
Should I replace the hazard switch?
What's the deal with my left brake light being out as well as that original rear turn signal? Are they related in wiring??
If I were car savvy...
gorollover is offline   Reply With Quote
Old 04-09-2009, 06:47 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: 2002 L200 - Hazard/Turn Signals not working. Plus driver's side brake light.
Turn signals and hazard switch not working is burned out flasher, fairly common problem with the L's. The flasher is integral to the hazard switch. New hazard switch is about $35 and easy DIY replacement. Pull off the bezel on the center control panel and using 2 small screwdrivers, push in the tabs on the sides of the hazard switch and pull the switch out.
There was a recall on brake lights for flimsy common electrical plates that warped easily. Have you had the tail light recall done?
Jerry N
Groucho Marx
Old 04-21-2015, 12:56 PM   #3
aaajessy
aaajessy has a spectacular aura aboutaaajessy has a spectacular aura about
2002 L-Series 2.2L Sedan
I thought is post a quick reply for anyone else who had this problem. My left blinker wasn't working but the bulb, fuses and relays were fine. I was about to buy a tail lamp connector plate when I read that all it takes is a simple fix. Bend the connectors on the bulb holder forward away from the plastic and it works!!
aaajessy is offline   Reply With Quote
98 sl2 - turn signals not working / hazards working normal Jetfixer10 S-Series Tech 17 01-16-2022 06:02 PM
91 sl2 turn signals hazard not working speed racer S-Series Tech 0 03-19-2009 04:59 PM
91 sl2 turn signal/hazard not working speed racer S-Series Tech 1 03-12-2009 08:26 PM
Turn signals are not working??? Daredevil6534 S-Series General 1 01-26-2009 11:01 PM
Driver's side brake light out corn_dog S-Series Tech 7 03-26-2008 03:26 AM
