Old 04-01-2017, 01:48 PM   #1
cirdanlunae
cirdanlunae is on a distinguished road
1997 SW2
Default Radio antenna adaptor question
Hi folks! New to the forums. I've been a lurker for a while, and I thought I'd ask my first question.
I went to a local salvage yard to get a stock radio for my 97 SW2. They pulled the radio from a 99 S-series. The power/audio/etc. connector works fine. The antenna plug, however, didn't fit into the radio. Did different year cars have different size antenna plugs? Does anyone have experience in this?
cirdanlunae is offline   Reply With Quote
Old 04-01-2017, 01:51 PM   #2
Default Re: Radio antenna adaptor question
There is an adapter you have to use. GM antenna adapter. Be sure you get the one that has the 90 degree plug on the radio end. Example--- http://www.ebay.com/itm/American-Int...5Y2XsH&vxp=mtr
Old 04-01-2017, 04:11 PM   #3
Same size antenna '91-'02 so either the "new" radio isn't stock or the "old" radio wasn't and you just need to pull the adapter off.
Old 04-02-2017, 01:07 AM   #4
cirdanlunae
1997 SW2
The new unit I put in is definitely stock. Right from a 99 s series, Saturn logo and all. The old one was after market, but the antenna plug is standard... No adaptor on it. I can take it apart and snap a pic of what exactly the scenario is. Can't do that till Monday. It's odd...I figured the units would be the same on the back. Isn't it just a standard Motorola connector for these radios?
Old 04-02-2017, 10:47 AM   #5
The plug you are looking at on the antenna lead is an extension cable with a STANDARD diameter plug. You need to trace it back until you fid the actual antenna lead and disconnect the AFTERMARKET adapter and then get the GM10 adapter I linked you a picture of.
Top 2 rows. http://www.metraonline.com/search?q=...&submit=submit
Old 04-08-2017, 08:38 PM   #6
cirdanlunae
1997 SW2
@OldNuc, took my radio off today and checked the antenna. Had no idea there was an adaptor there...I honestly thought the plug WAS the end of the lead. Took it off, and the plug underneath fit the radio perfectly. Thanks for the help!
1997 Saturn SW2 - happy 20th birthday!
Old 04-08-2017, 09:46 PM   #7
Yes there is also an adapter to convert the GM-10 to the older larger plug. Usually what you find is the actual lead from the car antenna is relatively short and ends above the glove box left side. At that point the large to GM-10 adapter cable is attached. Some aftermarket installs will remove that GM-10 adapter and replace it with a large size plug and socket adapter so the cable reaches the radio.
antenna, radio
Radio Antenna Question cola Vue Red Line 4 05-30-2012 06:51 AM
Need some car FM/AM radio antenna help!!! SuperCujo S-Series General 13 07-28-2009 03:49 PM
Satellite radio antenna install question cneyedog Vue Mods 0 07-07-2007 08:31 AM
2006 vue radio kit, onstar adaptor????? centerx49 Vue General 1 03-10-2006 02:07 PM
XM Radio Antenna tominsky Vue General 23 02-02-2004 07:22 PM
