Old 01-30-2012, 01:15 PM   #1
DB42
DB42 is on a distinguished road
DB42's Avatar
Default My journey. Car back from shop
Ive been postong on here (the tech section)about my journey of getting this car fixed after break down. It did use alot of oil about a 1/2qt a day I drive about 80 miles a day. Started getting ses codes= misfires, egr,o2 codes tried fixing them they would just come back. Then it finally just quit on me one day while driving so I finally had enough and so did my girlfriend she works at a car dealership so she told my stubborn @ss to get it towed there and I did it was the fuel pump and a blown head gasket so I figured too that it could be pistons and rings cause of oil use so had them look at everything in the engine. Well it ended up being 2 pistons and rings, blown head gasket, intake leak, they said they would do a engine rebuild and would only charge me for 7hours labor I said YES thats a good deal!
Heres all of what they did all new.
Fuel pump
Fuel filter
Head gasket set
4 pistons
all rings
Timing chain kit upgraded one. I said while ur that far in put new timing chain in.
2 axel seals
and tow was in the bill was $1865 not bad
The car runs like new and the oil after diving now for over 200 miles is super clear AND HASNT USED ANY! They clean all the carbon and crap out of the engine, I cant believe how clear the oil is still. I now love that I dont need to check and add oil every single day anymore. I will still check it though!
Im hoping to get atleast 100.000 more miles out of this car now.
I have done so much to this car myself since Ive bought it about 8 months ago. From engine cradle, complete brake jobs, motor mounts, aluminum valve cover, belt, coils, icm, egr, TB cleaned, spark plugs, map sensor, ects and probably more things too. So all this work I save myself alot of money
1997 SL2 162000 miles
DB42 is offline   Reply With Quote
Old 01-30-2012, 01:17 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: My journey. Car back from shop
...you did make sure the pistons they used were the upgraded design with the drain holes in them right?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 01-30-2012, 03:20 PM   #3
spacemanspif
spacemanspif will become famous soon enough
spacemanspif's Avatar
If not, I hope he's planning on switching to Mobil 1 once the break in is completed...
-Mike
1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph
1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI
spacemanspif is offline   Reply With Quote
Old 01-30-2012, 08:37 PM   #4
adventureoflink
I hope you mean the fully synthetic one right...? (assuming of course all seals were re-done in addition to the gaskets)
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 01-31-2012, 12:21 AM   #5
spacemanspif
The reason you buy Mobil 1 is for synthetic motor oil, anyone that is buying the blends and that other stuff they offer is just wasting money on the M1 label. If Mobil 1 is recommended to you by someone, they mean the synthetic oil, not synthetic-ish. I don't know why they make anything else, they had the market dominated when all they made was "M1 synthetic motor oil" so much so that people didn't tell you to run synthetic, they said run M1...and now they make all these other types that just confuse people into thinking they are getting their money's worth out of sub-standard oil.
-Mike
Old 01-31-2012, 09:56 AM   #6
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
Penzoil ultra synthetic will keep your engine 25% cleaner than mobile 1 heard it on a autoradio internet show.. thought i would pass it along.
" Any man that doesen"t share his knowledge in cars is wrong to do !"
brags is offline   Reply With Quote
Finally Got our Outlook Back from the Body Shop! Big O Outlook General 1 04-02-2010 08:01 PM
Back in the shop... 4littlemonkeys Relay General 5 09-04-2007 05:35 PM
just got my black rl back form the body shop srcauto rlvue Vue Red Line 5 09-11-2006 11:42 PM
got my cam cover back from powder coating shop mtlmutt Ion General 12 04-11-2004 11:11 AM
My baby is back from the shop! YELO_SC2 S-Series General 6 08-23-2003 09:15 PM
