Old 12-28-2011, 05:05 PM   #1
desertrat
desertrat is on a distinguished road
2000 SC1
Default Can I add cruise control to my SC1 from another Saturn??
My SC1 doesn't have cruise control. Was wandering if a unit from another Saturn will work on mine and what needs to be done?? Thanks.
desertrat is offline   Reply With Quote
Old 12-28-2011, 06:08 PM   #2
Default Re: Can I add cruise control to my SC1 from another Saturn??
Not as easily as if you had an earlier model without a BCM.
I'd offer you mine, but it won't work in yours and it's too cold to work around that much brittle plastic now. "Broke" mine by putting in the same 5spd you have.
There's other threads listing what you'll need and how to do it. I believe it's just the steering wheel module/switch, the thingy that goes onto the gas pedel, probably some wiring, and reprogramming the PCM with a Tech II or equivalent.
Old 12-29-2011, 11:28 AM   #3
I believe that the with a 2000, you need the whole steering wheel from a 3rd gen car (2000-2002) as the controls are in the steering wheel rather than a pod mounted on the shaft cover
If you go to YouTube and look for videos by richpin06a, he covers the process for a 2nd gen. When you grab the module that attaches to the gas pedal, be sure and grab the rubber grommets, too.
No wiring needed, should all be in place; just need to connect it under the steering wheel
Old 12-29-2011, 11:11 PM   #4
Alot depends on the model level of the car. The lower option levels did nmot have the ability to have cruise installed. The best way to check if you can even think of installing cruise is to see if you have the wiring harness connector for the cruise control module. The connector should be taped up by the base of the steering column/gas pedal area. No connector no way of installing OEM cruise.
Old 12-29-2011, 11:38 PM   #5
off-track
off-track's Avatar
^+1
Even if it's there. You will need the CC wheel as ALOC mentioned, the module itself, AND have the option turned on via a Tech-II scanner.
Search "adding cruise" here and you will find several threads on the subject.
Purchased 114k 10/07
Added OEM CC
1999 Saturn sl1 cruise control PCR21688 S-Series Tech 22 10-24-2015 03:29 PM
Cruise control 2002 Saturn vue tiggerooh Vue General 5 06-23-2011 02:11 PM
1995 Saturn cruise control add on AlainMDavos S-Series General 2 01-06-2009 10:48 PM
94 saturn no cruise control checked fuse,trans? tall3oy S-Series Tech 8 02-25-2008 12:35 PM
2000+ Saturn S-series cruise control diagram hookem202 S-Series Mods 0 12-15-2007 05:05 PM
