Old 06-22-2011, 12:49 PM   #1
tiggerooh
tiggerooh is on a distinguished road
Default Cruise control 2002 Saturn vue
My cruise control will not activate.It worked just fine for years but now the cruise light comes on but will not activate when setting.I did have some rain water get onto the driver side panel near the analizer socket ----forgot to close windows during a rain storm .However, at that time, the cruise still worked for several months after that mishap.
tiggerooh is offline   Reply With Quote
Old 06-22-2011, 04:53 PM   #2
VTchemist
VTchemist's Avatar
Default Re: Cruise control 2002 Saturn vue
It may be the switches on the steering wheel. On the 02 and 03 models, you can pry the switches out of their setting (on the front of the steering wheel) using a flathead screwdriver. They come apart and clean nicely.
I had this problem. There was crud in the switches. If the button membrane doesn't make contact, you may not be able to turn in on, or either increase or decrease the speed.
It is a 10 min job. Qtips and alcohol work great.
Old 06-22-2011, 05:18 PM   #3
tiggerooh
Thanks VTchemist I'll give it a try and see what happens.
Old 06-22-2011, 11:01 PM   #4
tiggerooh
Well, the switch on the cruise control was cleaned and returned ----but still no go.Although the cruise turns on ,it does not activate the cruise speed apparently it must be --that no power is getting to the electronic device that activates the cruise. So I believe something is wrong with the circuit.But I have no schematic of the cruise electrics.
Any other suggestions would be appreciated.
Old 06-23-2011, 09:57 AM   #5
far2grumpy
far2grumpy's Avatar
The cruise "ON" light indicates at least one contact of clock-spring coil is good.
There are two switches connected to brake pedal. They could be mal-adjusted. I doubt if its the stop-lamp switch. If it were ON at all times the brake lights would stay on.
You can find a schematic and switch adjust instructions in post # 18 of following thread.
http://www.saturnfans.com/forums/sho...d.php?t=130677
Old 06-23-2011, 02:11 PM   #6
tiggerooh
Thanks far2grumpy for the thread location will study this .
Add cruise control to 2002 SL1? brubro S-Series General 17 05-01-2013 05:55 PM
cruise control installation for 2002 SL1 sturgeon S-Series Mods 2 02-24-2010 01:21 AM
2002 sl1 cruise control install? homba S-Series General 11 09-22-2008 07:00 PM
Cruise control on a 2002 SL2 actnbill S-Series General 0 08-07-2006 05:42 PM
2002 SL Cruise Control .....Need Help jared myers S-Series General 1 12-27-2003 12:46 AM
